Problem with sound
  Kernel: 6.1.53-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=8bd862b2-ecd4-47ec-8e25-98cb971c65aa rw rootflags=subvol=@
  Type: Laptop System: LENOVO product: 20CLS05500 v: ThinkPad X250
  Mobo: LENOVO model: 20CLS05500 v: SDK0E50510 WIN
    serial: <superuser required> UEFI-[Legacy]: LENOVO v: N10ET59W (1.38 )
    date: 08/15/2019
  ID-1: BAT0 charge: 16.5 Wh (98.2%) condition: 16.8/23.2 Wh (72.2%)
    volts: 12.3 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
    status: not charging
  ID-2: BAT1 charge: 17.9 Wh (100.0%) condition: 17.9/23.2 Wh (77.2%)
    volts: 12.3 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
    status: full
  Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 795 high: 798 min/max: 500/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 789 3: 798 4: 797
    bogomips: 18367
  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
  Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:6 chip-ID: 04ca:703c
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x05e0 built: 2013 res: 1366x768
    hz: 60 dpi: 125 gamma: 1.2 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
    ratio: 16:9 modes: 1366x768
    missing.
  Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
  API: ALSA v: k6.1.53-1-lts status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
    status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
  Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
    port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
  IF-ID-1: wwp0s20u4 state: down mac: <filter>
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:5 chip-ID: 8087:0a2a
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
  Local Storage: total: 238.47 GiB used: 22.96 GiB (9.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HCHP-000L7
    tech: SSD serial: <filter> fw-rev: 3L6Q scheme: MBR
  ID-1: / raw-size: 37.64 GiB size: 37.64 GiB (100.00%) used: 12.6 GiB (33.5%)
    fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 168.41 GiB size: 168.41 GiB (100.00%)
    used: 10.37 GiB (6.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-3: /var/log raw-size: 37.64 GiB size: 37.64 GiB (100.00%)
    used: 12.6 GiB (33.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-4: /var/tmp raw-size: 37.64 GiB size: 37.64 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.47 GiB used: 7 MiB (0.1%) priority: 100
  System Temperatures: cpu: 46.0 C pch: 45.5 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2576
  Processes: 253 Uptime: 42m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 7.47 GiB used: 4.09 GiB (54.7%) Init: systemd v: 254
  pm: pacman pkgs: 1406 libs: 401 tools: gnome-software,pamac,paru Shell: Bash
  v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.29
  System install date:     2023-08-14
  Last full system update: 2023-09-15 ↻
Hi, I’m having problem with sound every 3/4 days, I started with Pipewire only, but the volume of the sound was very low, so I tryed to add Alsa support through Garuda assistant, and for a couple of days it was ok, but then I couldn’t play any sound and the video online and didn’t not work, they stopped. The videos were working on vlc without sound. So I tryed to delete (always through G assistant) Alsa and Pipewire and install them again, after that the system was working for a couple of days, than again blocked! So I tryed avery combination with Pipewire, Alsa and pulse and always I was able to get the system work for few days, but than again it was blocked. If you can help with some ideas I’ll be glad! Thank you in advance! (I have two other computers, a desktop and a laptop where everything is working fine!)
Please check if this helps:
https://wiki.archlinux.org/title/Lenovo_ThinkPad_X250
Thanks filo! Unfortunately I tryed to install asoundconf but nothing untill now!
Have you tried also the config?
/etc/modprobe.d/thinkpad-x250.conf
options snd_hda_intel index=1,0
