Actually I switched from Arch linux which was installed ext64 on lvm partition. I removed that OS and installed garuda on that partition. But save the data from that OS in seperate partition and mounted it with garuda. But user of that Arch and current Garuda OS is same and files is saved in same name. When I try to login in garuda with same user nae created User, can't able to login and error is:
