Please check of disabling in the BIOS Intel-VMD helps.
Be aware that if dual booting with Windows, Windows could not start with this setting.
But this would be solvable...
If this doesn't work, provide as text the outcome of inxi -Fxxxza from the terminal
Edit: I probably misunderstood the problem. I wrote in the assumption that you managed to install and the error was prompted at first boot.
Now I see that you're probably experiencing the problem even from the USB.
In this case I'd suggest:
verify the checksum of the downloaded ISO file
try a different USB port
try a different USB key
you didn't mention which tool you used to prepare the USB. I think Balena Etcher and Ventoy are the preferred options, but you may want to try changing also this tool
