Problem running games with Wine and firewire audio
I just switched to a firewire audio device, and I can’t play games with Wine, either through Steam or Lutris. Some just output no sound, but most won’t run at all because they say I have no audio device. I installed pipewire-ffado, but it didn’t help. Audio works fine with everything except Wine. I’ve messed with my prefix, neither setting to system default or directly selecting the audio device works… but Wine sees my device just fine. I’m not sure what else to try. Anyone have any experience with this?
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 948 high: 1100 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1099 3: 800
4: 800 5: 1074 6: 800 7: 1100 8: 800 9: 1100 10: 1100 11: 1096 12: 1100
13: 799 14: 800 15: 1095 16: 800 17: 1100 18: 800 19: 1100 20: 800 21: 800
22: 1100 23: 800 24: 800 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:7
chip-ID: 1532:0e03 class-ID: 0102
Device-3: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:9 chip-ID: 534d:2109
Device-4: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:4
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
Device-5: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.2:8
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: PreSonus Audio AudioBox USB driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.4:18
chip-ID: 194f:0302 class-ID: 0103
Device-4: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-5: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-6: MacroSilicon USB Video
Device-7: Elgato Systems GmbH Game Capture HD60 X
Device-8: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 43.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:21 chip-ID: 8087:0033
Local Storage: total: 9.56 TiB used: 1.69 TiB (17.7%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 55.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:5 vendor: Western Digital
fw-rev: 731100WD temp: 53.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Corsair model: Performance Pro
tech: SSD serial: <filter> fw-rev: 1.0 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.41 TiB (77.3%)
used: 1.3 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.41 TiB (77.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 431.5 MiB (0.7%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 539
Processes: 588 Uptime: 32m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 7.74 GiB (12.4%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2197 libs: 596 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-05-03
Last full system update: 2024-01-22
Without garuda-inxi this request will be moved to 412 Precondition Failed
Sorry, forgot.
Please :slight_smile:
Ugh… I misread, thought you said with it collapsed. lol. Ok, done.
I couldn’t figure this out, so I ended up having to put a USB audio interface back in the chain. Pretty dumb, but my audio source for pipewire is set to a Presonus Audiobox, which is plugged into a hardware mixer and then into my firewire interface with input monitoring turned on. Lol. But at least games in Wine work again.
There is obviously something wrong with my driver setup. The research I have done says to blacklist the ALSA firewire drivers and use Jack + FFADO. I have FFADO and pipewire-ffado installed, as well as pipewire-jack. My understanding is you don’t need actual Jack when using pipewire… but I’m not sure what to do. I tried blacklisting the drivers as suggested, but then I just no sound at all in pipewire. ffado-mixer still sees the device, but no source is selectable in the KDE audio settings. So… I’m still searching for answers…
