I have a triple monitor setup and recently swapped one of the monitors in my setup to a new higher resolution and refresh rate one, and I rearranged the existing one so the new one is in the center, and since then I have been experiencing some issues with my display configuration. I was able to configure and arrange the monitors in the display settings exactly as expected, I set it to the primary display and arranged the monitors to match the physical arrangement of the monitors, however for the last few days since the upgrade the new monitor keeps getting a no signal message and goes into sleep mode on a regular basis, usually after the OS locks due to inactivity but sometimes while I am actively using the system. If I reopen the display settings configuration section of system settings I can still select the center monitor, which is powered off, but the checkmarks next to enabled and primary are unchecked. Checking the enabled and primary boxes will turn the new monitor back on, however it gets added into the arrangement as the rightmost monitor so I have to redo my monitor arrangement as well. I did a bit of searching online but couldn't find anyone with a solution to a similar problem. Is there a way to fix this?
Kernel: 6.0.10-AMD arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd
root=UUID=3d798106-08a8-4e21-ab6d-a5ae3a7f3b7a rw [email protected]
quiet
cryptdevice=UUID=b6b2201e-12f5-4301-85d4-466e639978b5:luks-b6b2201e-12f5-4301-85d4-466e639978b5
root=/dev/mapper/luks-b6b2201e-12f5-4301-85d4-466e639978b5 quiet splash
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3523 high: 3600 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3595 2: 3400
3: 3595 4: 3400 5: 3400 6: 3400 7: 3400 8: 3600 9: 3596 10: 3595 11: 3598
12: 3600 13: 3400 14: 3598 15: 3596 16: 3597 bogomips: 108840
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 0c:00.0
chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 7680x1440 s-dpi: 96 s-size: 2032x381mm (80.00x15.00")
s-diag: 2067mm (81.39")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,center
model: Samsung LS27AG55x serial: <filter> built: 2021 res: 2560x1440 hz: 165
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: Samsung C27HG7x
serial: <filter> built: 2033 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: left model: BenQ LCD
serial: <filter> built: 2016 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 14.0.6 DRM 3.48 6.0.10-AMD) direct render: Yes
bus-ID: 1-1.3:4 chip-ID: 1532:0511 gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 serial: <filter> bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA RZ19-0229 Gaming Microphone type: USB
Sound API: ALSA v: k6.0.10-AMD running: yes
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 168c:0034 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 3-6:3
chip-ID: 0489:e076 class-ID: e001
Local Storage: total: 3.38 TiB used: 387.07 GiB (11.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 type: SSD serial: <filter> rev: RKT401.3 temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: PCIe SSD size: 931.51 GiB
type: SSD serial: <filter> rev: EHFM31.1 temp: 50.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SP550 size: 223.57 GiB
serial: <filter> rev: 3B5a scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Mushkin model: MKNSSDCR480GB-7-A
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 105.7 GiB (11.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b6b2201e-12f5-4301-85d4-466e639978b5
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
System Temperatures: cpu: 55.6 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 56.0 C
Processes: 500 Uptime: 3d 15h 20m wakeups: 0 Memory: 31.27 GiB
used: 11.92 GiB (38.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1921
libs: 545 tools: octopi,paru Shell: fish v: 3.5.1 running-in: yakuake
inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-10-22
Last full system update: 2022-11-30 ↻
Failed units: plymouth-deactivate.service plymouth-start.service
Have you tried changing the cable?
I would be curious to see if you notice any different behavior out of the monitor if you connect Monitor-1 with the HDMI cable from Monitor-3, and connect Monitor-3 with the DP. I'm not saying you'd have to leave it like that--just change it for the sake of troubleshooting.
valanduin:
I swapped the cables between monitors one and 3, although the displayport input on monitor 3 is dead as far as I can tell, I have tested it with multiple cables and it doesn't detect any cable connected on the displayport cable when one is plugged in. My graphics card only has one HDMI port though, so I am down to 2 monitors as it is. I will try this for a day or two and if I don't have issues with screens being shut off I guess I will need to get a displayport to HDMI adapter
petsam
3 December 2022 00:50
4
valanduin:
built: 2033
Monitor 2 has come back from the future
On topic, check onboard settings of the monitor in problem, for power saving settings. Disable any DPMS (power saving), to test for any behavior change.
tomcat
3 December 2022 02:41
5
I've had this issue as well since the last major update to KDE. I'm wondering if it has to do with KScreen or KWin, but in any case, I'm also running Garuda Linux with zen kernel and KDE Plasma.
Monitor displays fine until login, then power cycles after entering the password. I've been able to get it on again with nvidia-settings
(you'll need to run as sudo to save config to X). My DP monitor shows up as "disabled". First enable it and leave the HDMI monitor as primary, and Apply. I've tried marking as primary first, but settings revert. Then, after the monitor kicks on, mark as Primary and Apply again. Save configuration to X. You may need to reapply additional configs like your monitor refresh rate, and G-Sync if you're using it, as sometimes these settings are disabled. I've been able to reliably get my monitor back up and running in this admittedly roundabout way. One caveat: if you walk away long enough that the monitor goes to sleep, the monitor is disabled again, and you need to do the whole thing over again.
I've posted about this on KDE forums as well, but I'm unsure if this is unique to Garuda based on the lack of search results.
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4350e34a-a170-4085-ab6b-dea58f40d93e rw [email protected]
cryptdevice=UUID=0bfab363-815b-4b0d-90ba-bbed136e65a9:luks-0bfab363-815b-4b0d-90ba-bbed136e65a9
root=/dev/mapper/luks-0bfab363-815b-4b0d-90ba-bbed136e65a9 splash
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1301
date: 03/14/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2962 high: 4200 min/max: 800/4500:5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 4200 3: 4200
4: 4200 5: 4200 6: 4200 7: 900 8: 900 bogomips: 67200
vulnerable
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: eVga.com.
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 4480x1440 s-dpi: 93 s-size: 1224x389mm (48.19x15.31")
s-diag: 1284mm (50.56")
Monitor-1: DP-0 pos: primary,top-left res: 2560x1440 hz: 60 dpi: 109
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
driver: snd_hda_intel bus-ID: 1-6:4 v: kernel bus-ID: 00:1f.3
chip-ID: 1395:005e chip-ID: 8086:a2f0 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-3: DSEA A/S GSX 1000 Main Audio type: USB
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-14.1:8 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 11.83 TiB used: 384.54 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 960 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7
temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO
250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
temp: 24.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWE160
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: FS2A scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD40NDZW-11A8JS0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1034 scheme: GPT
ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 37.95 GiB (12.7%)
mapped: luks-0bfab363-815b-4b0d-90ba-bbed136e65a9
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%) used: 724 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:8
ID-3: /home raw-size: 631.02 GiB size: 631.02 GiB (100.00%) used: 346.58
GiB (54.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23daf038-216d-4bc5-bf5b-9ab9682afb7f
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%) used: 37.95 GiB
(12.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%) used: 37.95 GiB
ID-1: swap-1 type: zram size: 31.28 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 46%
Processes: 331 Uptime: 17m wakeups: 0 Memory: 31.28 GiB used: 4.98 GiB
(15.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1858
libs: 509 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Zsh v: 5.9
running-in: alacritty inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2021-11-26
Last full system update: 2022-11-03
Edit: formatting
tbg
3 December 2022 18:16
6
I see monitor 1 is using a 2560x1440
resolution. You need to make sure all cabling and adapters are rated for resolutions above the 1080p standard. Older or cheaper cables and adapters will likely be only 1080p capable. Cheap DP to HDMI adapters from Amazon are usually only 1080p. Be sure any cabling or adapters you buy are rated for 4K, (8K is better to be future proof). Check all the online reviews if buying from online from retailers like Amazon, as many of their cheaper cables/adapters don't actually meet the standards the manufaturers claim. That is why buying 8K is better, because you can at least be pretty sure it should at least be 4K rated to meet future requirements.
