navneet
February 10, 2023, 2:06pm
1
initially had a problem with wifi that was fixed with some guidance and hit and try, but have another one that i am facing now
i previously was connected to a 5gz network and now after i booted my laptop i cannot see that in the list nor am able to connect, what can i do to resolve this issue
filo
February 10, 2023, 3:27pm
3
Have you already tried restarting your router?
If done or not working, try lowering the channel on the 5GHz band to 40 or below and restart the router again.
Kayo
February 10, 2023, 3:42pm
4
Are you still dual booting Windows like stated here? Laptop doesnt shutdown - #6 by navneet
If that is still the case, I am assuming the issue is with "fast startup" being on in Window's power settings. Be sure to shut that off in Windows so it can release the wifi card so it can work in linux properly.
navneet
February 10, 2023, 4:35pm
5
how can i do these both please help
navneet
February 10, 2023, 4:41pm
7
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c30620e0-87af-43f2-ab3f-82d276571f8d rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 32.5 Wh (91.5%) condition: 35.5/48.1 Wh (73.9%)
volts: 10.9 min: 11.7 model: FX50442 type: Li-ion serial: N/A
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1316 high: 1627 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1351 2: 1396
3: 1253 4: 1627 5: 1245 6: 1242 7: 1221 8: 1197 bogomips: 33536
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
ports: active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 50.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.1.9-zen1-1-zen) direct render: Yes
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
IF-ID-1: enp5s0f3u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Huawei YAL-AL00 type: USB driver: rndis_host v: kernel
bus-ID: 1-2:5 chip-ID: 12d1:108a class-ID: 0a00 serial: <filter>
Device-2: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
Local Storage: total: 476.94 GiB used: 13.36 GiB (2.8%)
model: MZVLQ512HALU-00000 size: 476.94 GiB block-size: physical: 512 B
rev: FXV7000Q temp: 26.9 C scheme: GPT
ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 13.33 GiB (17.8%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 75 GiB size: 75 GiB (100.00%)
used: 13.33 GiB (17.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 75 GiB size: 75 GiB (100.00%)
ID-5: /var/tmp raw-size: 75 GiB size: 75 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.5 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 266 Uptime: 5m wakeups: 1 Memory: 13.59 GiB
used: 2.15 GiB (15.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1162
libs: 308 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-02-05
Last full system update: 2023-02-05
filo
February 10, 2023, 4:42pm
8
My suggestion needs that you have access to your router's web admin page (usually pointing your browser to your internal router ip address) and of course an admin account.
How to do it depends on your router and if your ISP allows that, which is normally the case.
navneet
9
i see every WiFi i connect to disappears on the next boot
navneet
February 10, 2023, 4:43pm
10
but this isnt happening on my windows in same laptop
filo
February 10, 2023, 4:48pm
11
Ok, good to know now, so @Kayo might have given you a better hint. Windows tends to keep a stong foothold on the hw...
navneet
February 10, 2023, 5:00pm
12
it didnt work for me, i tried with turning of 'Fast Startup', what other solution do we have?
filo
February 10, 2023, 6:57pm
13
My only idea is to try the rtw88-dkms-git
proprietary driver from the chaotic-aur.
Should it be necessary to blacklist the kernel module rtw88_8822ce give a look at the upstream site
