Hello,
As the title says, pressing Ctrl + Alt switches to tty4.
It appears that sometimes my keyboard is pressing F4 by itself.
I sometimes see this in terminal just writing out:
SOSOSOSOSOSOSOSO
I checked my keyboard key and it is not sticky.
I checked my keyboard in BIOS Diagnostics and everything is in order.
When I run sudo kbd_mode it shows:
The keyboard is in unknown mode
Running sudo kbd_mode -s fixes the problem until reboot.
Is there any permanent fix for this?
inxi -Faz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9d9588e0-3528-417d-969b-f7675645849e rw rootflags=subvol=@ quiet splash
rd.udev.log_priority=3 random.trust_cpu=on vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=915bc289-3518-43ad-83a3-f27ed97bb979
nvme_core.default_ps_max_latency_us=0 loglevel=3
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: XPS 15 9500 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 0W4CRC v: A03 serial: <filter> UEFI: Dell v: 1.9.1 date: 08/11/2021
Battery: ID-1: BAT0 charge: 5.1 Wh (9.3%) condition: 54.8/54.9 Wh (99.9%) volts: 10.7 min: 11.4
model: BYD DELL DVG8M11 type: Li-poly serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39999
Speed: 800 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 0bda:5510 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: eDP1 res: 1920x1200 dpi: 143 size: 340x210mm (13.4x8.3") diag: 400mm (15.7")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks driver: iwlwifi v: kernel
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 476.94 GiB used: 109.82 GiB (23.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000LNP size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: V9002s65 temp: 32.9 C scheme: GPT
Partition: ID-1: / raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 109.77 GiB (23.9%)
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 49.4 MiB (19.3%) fs: vfat
ID-3: /home raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 109.77 GiB (23.9%)
ID-4: /var/log raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 109.77 GiB (23.9%)
ID-5: /var/tmp raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 109.77 GiB (23.9%)
ID-1: swap-1 type: partition size: 16.92 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.25 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 283 Uptime: 20m wakeups: 2607 Memory: 15.25 GiB used: 3.13 GiB (20.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1595 lib: 496 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.07
