Greetings! Got a problem using Garuda Linux on KDE. After fresh install there's no battery icon on the top. Moreover there is the problem in KDE Settings where in Power Management Tab there's a huge saying "Power management configuration module could not be loaded. The Power Management service appears not to be running." I don't know what to do. There is no such service or deamon in Startup and Shutdown tab like people say. Even the reinstall didn't help.
You’re missing garuda-inxi,
seems like the solution there drove you straight to KDE.
Nothing is older than an inxi from yesterday, so please always include.
But, if you freshly installed and upgrade the system, we do not know without the inxi if there are still other problems, or if they just need to reboot the system,
same problem here: power management seems not to start. FWIW, my inxi here
```text
Kernel: 6.1.35-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=7ef913b1-020d-4883-935f-3015f690f1af
rw rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Mini-pc Mobo: AZW model: SER v: Version 1.0 serial: <superuser required> UEFI: American
Megatrends LLC. v: 113 date: 02/21/2023
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3+ gen: 4
level: v3 note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68)
stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1838 high: 3200 min/max: 1600/4828 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3076 2: 1396 3: 1395 4: 1396 5: 1396 6: 1396
7: 1394 8: 1395 9: 1395 10: 3200 11: 1392 12: 3200 13: 1392 14: 3200 15: 1396 16: 1392
bogomips: 102243
Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6 bus-ID: 74:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 45.0 C
Device-2: Lenovo 500 RGB Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-1.4.4:8 chip-ID: 17ef:482f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00") s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Sceptre Q32 serial: <filter> built: 2019
res: 2560x1440 hz: 60 dpi: 92 gamma: 1.2 size: 708x398mm (27.87x15.67") diag: 806mm (31.7")
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (rembrandt LLVM 15.0.7 DRM 3.49
6.1.35-1-lts) direct-render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 74:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 74:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 74:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: FIFINE 683 Microphone driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1.4.1.1:7 chip-ID: 3142:0031 class-ID: 0102
API: ALSA v: k6.1.35-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth driver: btusb v:
0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 465.76 GiB used: 11.91 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G size: 465.76 GiB
fw-rev: SBJ00101 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 268.05 GiB size: 268.05 GiB (100.00%) used: 11.88 GiB (4.4%) fs: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.4 MiB (30.6%) fs: vfat
ID-3: /home raw-size: 268.05 GiB size: 268.05 GiB (100.00%) used: 11.88 GiB (4.4%) fs: btrfs
ID-4: /var/log raw-size: 268.05 GiB size: 268.05 GiB (100.00%) used: 11.88 GiB (4.4%) fs: btrfs
ID-5: /var/tmp raw-size: 268.05 GiB size: 268.05 GiB (100.00%) used: 11.88 GiB (4.4%) fs: btrfs
ID-1: swap-1 type: zram size: 28.14 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 422 Uptime: 4m wakeups: 0 Memory: available: 28.14 GiB used: 3.18 GiB (11.3%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1375 libs: 383 tools: octopi,paru Client: shell wrapper v: 5.1.16-release
inxi: 3.3.27
System install date: 2023-06-24
Last full system update: 2023-06-24
This morning an update for powerdevil came in. At least for me, now everything seems to work again.
