Power Draw Low in GreenWithEnvy
inxi -Faz output:
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4226ebc7-7e0a-4c2d-8586-f0d9eafbaddb rw [email protected]
Type: Desktop Mobo: ASUSTeK model: SABERTOOTH Z170 MARK 1 v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3801
date: 03/14/2018
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4160 high: 4229 min/max: 800/4200:4300 scaling:
driver: intel_pstate governor: performance cores: 1: 4158 2: 4170 3: 4189
4: 4142 5: 4109 6: 4160 7: 4229 8: 4123 bogomips: 63999
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:13c0
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: DP-4 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA 495.46
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fbb
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:2 chip-ID: 08bb:2902
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: b000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.07 TiB used: 40.63 GiB (1.9%)
model: SSD 950 PRO 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 1B0QBXX7 temp: 23.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 14.53 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 40.63 GiB (17.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
I've been having stuttering issues on my desktop (and all programs).
This started on Win10, and after countless hours of trying to 'fix' windows I decided to switch to Garuda Linux (which I am much preferring so far).
However the stutters are continuing (I've tried with both proprietary and open-source drivers), and am currently using proprietary drivers since games wouldn't launch with the open-source drivers.
The Nvidia 'GreenWithEnvy' config tool shows Power 'Draw' varies between 60-80W, while the 'Min' is set to 120W in that same program (all on default settings + fresh install of garuda). I suspect this may be the cause of the issue, but I am not knowledgeable enough on how to fix it myself.
Also I'm running on a refresh rate of 144hz incase that's important.
Any help would be much appreciated.
Do you heavily use GPU or purchased second hand GPU or something like that?
These are indications of degrading GPU health.
And this needs some physical care instead of software one.
Try
  1. Cleaning your PC motherboard as well as GPU thoroughly.
  2. Changing thermal paste.
  3. Searching on web in this regard.
I hope this helps.
