I installed Garuda without enabling disk encryption. I have everything set now, and even have couple of btrfs snapshots.
Is it possible to encrypt the drive(SSD) now? Or does it have to be on fresh install only?
If possible, how?
╰─λ inxi -Faz
System: Kernel: 5.14.12-arch1-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.dyndbg=+p acpi.dyndbg=file drivers/acpi/x86/s2idle.c +p
amd_pmc.enable_stb=1 BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=2eeb1928-e215-484e-9847-54e2ce849c93 rw rootflags=subvol=@ quiet splash
resume=UUID=2978cdd3-cd08-43ba-b001-a7053ea59b54 loglevel=3
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <filter> UEFI: American Megatrends v: GA401II.219
date: 12/30/2020
Battery: ID-1: BAT0 charge: 50.8 Wh (69.0%) condition: 73.6/76.0 Wh (96.9%) volts: 15.8 min: 15.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71894
Speed: 1587 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1587 2: 1495
3: 1397 4: 1396 5: 1389 6: 1392 7: 1704 8: 1609 9: 1428 10: 1778 11: 1746 12: 1407
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.12-arch1-g14-1 LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.12-arch1-g14-1 running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:2723
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:3 chip-ID: 8087:0029
Drives: Local Storage: total: 953.87 GiB used: 299.28 GiB (31.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
rev: 004C temp: 27.9 C scheme: GPT
Partition: ID-1: / raw-size: 937.05 GiB size: 937.05 GiB (100.00%) used: 299.28 GiB (31.9%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 937.05 GiB size: 937.05 GiB (100.00%) used: 299.28 GiB (31.9%) fs: btrfs
ID-4: /var/log raw-size: 937.05 GiB size: 937.05 GiB (100.00%) used: 299.28 GiB (31.9%)
ID-5: /var/tmp raw-size: 937.05 GiB size: 937.05 GiB (100.00%) used: 299.28 GiB (31.9%)
ID-1: swap-1 type: partition size: 16.56 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.05 GiB used: 1.7 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 38.2 C mobo: 38.0 C gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): cpu: 2600
Info: Processes: 364 Uptime: 14h 29m wakeups: 42 Memory: 15.05 GiB used: 5.11 GiB (33.9%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1488 lib: 371 Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.07
