Possible Nvidia Driver Issue After Update
Hello,
I'm having an issue with a system update I did last night, and unfortunately in my attempts to sort it out it ended up doing too many snapper overwrites so my pre-update rollback is gone (I think?), oops...
The issue I'm having is that my Nvidia driver appears to be having some issues. You'll notice at the bottom of the Garuda Inxi output I have a failed systemd unit, this is just an automated script I run to set the power limit of my 3070 Mobile on boot to 64W. Now what happens if I run the command to do that manually is I get this message:
 ╭─user@6800H in ~ took 19s
 ╰─λ nvidia-smi -pl 64
Changing power management limit is not supported for GPU: 00000000:01:00.0.
Treating as warning and moving on.
All done.
If I run nvidia-smi alone my power usage will say something like 11W / N/A when before it would say 11W / 64W.
I'm wondering if there is a way to downgrade the Nvidia driver back to 525, or if there is anything else I can do.
The steps I've taken so far to try and fix it are seeing if there were any more updates today and installing a couple of kernels (LTS and Xanmod) using the Garuda Settings tool to see if that would fix it, but they haven't worked.
Also, not sure if it matters at all but I don't dual-boot!
Thanks!
Garuda Inxi:
  Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=3ee9b05a-af77-4cbf-bd94-85b0090437f6 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=3ac6c728-7c3c-43bd-beba-3838be95e33f:luks-3ac6c728-7c3c-43bd-beba-3838be95e33f
    root=/dev/mapper/luks-3ac6c728-7c3c-43bd-beba-3838be95e33f quiet splash
    resume=/dev/mapper/luks-558a2aec-5e05-4637-ab15-eeda4d0bcac0 loglevel=3
  Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA507RR_FA507RR
  Mobo: ASUSTeK model: FA507RR v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: FA507RR.314 date: 10/12/2022
  ID-1: BAT1 charge: 85.2 Wh (100.0%) condition: 85.2/90.2 Wh (94.4%)
    volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: full
  Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1678 high: 3200 min/max: 1600/4784 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1377 2: 1600
    3: 1338 4: 1600 5: 2070 6: 1731 7: 1596 8: 1600 9: 1600 10: 1677 11: 3200
    12: 1330 13: 1600 14: 1600 15: 1600 16: 1331 bogomips: 102204
  Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
  Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: 06:00.0
    chip-ID: 1002:1681 class-ID: 0300 temp: 53.0 C
  Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-4:2 chip-ID: 322e:202c class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.0
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Monitor-1: eDP-1 mapped: eDP model: TL156VDXP0101 built: 2021
    res: 1920x1080 hz: 300 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
  API: OpenGL v: 4.6 Mesa 23.0.0 renderer: AMD Radeon Graphics (rembrandt
    LLVM 15.0.7 DRM 3.49 6.2.8-zen1-1-zen) direct-render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel bus-ID: 4-1:2 v: kernel chip-ID: 0b05:6208 pcie:
    class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: ASUSTek C-Media Audio type: USB
  Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
    vendor: ASUSTeK driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 3-3:3 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Local Storage: total: 2.75 TiB used: 734.73 GiB (26.1%)
    model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
    rev: 234200WD temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
    model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
    rev: FXM7301Q temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 919.9 GiB size: 919.9 GiB (100.00%)
    used: 136.88 GiB (14.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-3ac6c728-7c3c-43bd-beba-3838be95e33f
    used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
  ID-3: /home raw-size: 919.9 GiB size: 919.9 GiB (100.00%)
  ID-4: /var/log raw-size: 919.9 GiB size: 919.9 GiB (100.00%)
  ID-5: /var/tmp raw-size: 919.9 GiB size: 919.9 GiB (100.00%)
  ID-1: swap-1 type: partition size: 33.66 GiB used: 0 KiB (0.0%)
    mapped: luks-558a2aec-5e05-4637-ab15-eeda4d0bcac0
  ID-2: swap-2 type: zram size: 30.6 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 61.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 404 Uptime: 11m wakeups: 929 Memory: 30.6 GiB
  used: 3.1 GiB (10.1%) Init: systemd v: 253 default: graphical
  pkgs: 1500 libs: 505 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
  v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
  System install date:     2023-02-28
  Last full system update: 2023-03-25
  Failed units:            nvidia-power-limit.service
could you check the files in /var/log/garuda and upload the one from the troublesome system update? There is probably one package that can be rolled back to get back to normal.
There you go, there's quite a lot of packages in the update :sweat_smile:
Sometimes I have issues with NVidia drivers after update.
You can use nvidia-all to re-install or install a specific version.
And yes you can downgrade with it.
Next time please use the text bin on the top right :wink:
I spotted these nvidia packages:
lib32-nvidia-utils-530.41.03-1
lib32-opencl-nvidia-530.41.03-1
nvidia-dkms-530.41.03-1
nvidia-settings-530.41.03-1
There are two packages that immediately pop out: nvidia-utils and nvidia-dkms. nvidia-utils contains the tool you use for power-management and nvidia-dkms is the kernel module.
Since the kernel module tends to manage things like this, I think you should start to downgrade that to the previous version. After that, maybe try nvidia-utils.
Thank you! I ended up putting all those packages you listed into downgrade and selected the cached 525 version of them all, and it's worked! Thanks again :grinning:
You should report the issue to nvidia, or you can never upgrade those packages again
