Possible GPU or driver issue?
Hello all,
I recently switched from Nobara to Garuda and I am having a few issues I believe to be GPU related. The most annoying of which is frames “skipping” while gaming. My FPS isn’t dropping to where it would explain the issue but I can stand still in the afk screen. I am assuming it is my 3060ti showing as “low power” in my graphics settings but I can’t find a way to change it in the Nvidia-settings menu. I am running the current driver 545.29.06 and the system is up to date. I am familiar enough with Linux to get by but not gaming on Linux so I am at a loss.
system:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3aeac27b-cae0-4382-a5f3-2188d7d73253 rw rootflags=subvol=@
quiet rd.luks.uuid=10cf9538-3e5f-428a-9011-2861e641d34a loglevel=3
v: 5.115.0 wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
UEFI: American Megatrends v: 4602 date: 07/31/2023
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3988 high: 4695 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3741 2: 3741
3: 4695 4: 3978 5: 3792 6: 3743 7: 3749 8: 3927 9: 3741 10: 3758 11: 4691
12: 4683 13: 3912 14: 3750 15: 3913 16: 4001 bogomips: 121600
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06
2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-1,DP-2 empty: DP-3,HDMI-A-1
bus-ID: 0b:00.0 chip-ID: 10de:2489 class-ID: 0300
Device-2: Sunplus Innovation Live Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 1bcf:2284 class-ID: 0102 serial: <filter>
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 5120x1440
display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 2560x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia wayland:
drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2489
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sunplus Innovation Live Camera driver: snd-usb-audio,uvcvideo
Device-4: Logitech Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:4
chip-ID: 046d:0ab9 class-ID: 0300 serial: <filter>
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0029
Local Storage: total: 7.79 TiB used: 121.64 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T2532TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
model: WD50NMZW-59BCBS0 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 4800 serial: <filter> fw-rev: 4004 scheme: GPT
used: 121.64 GiB (25.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-10cf9538-3e5f-428a-9011-2861e641d34a
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.7 GiB used: 4.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 50.0 C mobo: 36.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 13.94 GiB (22.2%)
Processes: 481 Power: uptime: 3h 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1952 libs: 551 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33~~~
garuda welcome 2
Have you tried running in x11 not wayland
My apologies but the only way I’m familiar with switching between Wayland and Xorg is from the login screen but that’s not an option on Garuda or am I missing something?
never mind I’m stupid, I found it
Thank you, after some brief testing switching to x11 appears to have corrected the frame skip issue. I appreciate the response.
