Poor contrast in system settings with dark theme
Whatever dark theme I choose, whether it be Breeze or the default Garuda theme, I get terrible contrast in the system settings app.
The attached screenshots will both demonstrate the issue and show my appearance settings.
I only have this issue in system settings app, and in System Tray Settings, which might actually be the same thing...
  Kernel: 5.15.68-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=1ae1827d-082e-4190-8d66-84aa16e7a79c rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm:
    1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Garuda Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 1203
    date: 10/10/2019
  Info: model: Intel Core i7-9700 bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
  Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 4299 high: 4558 min/max: 800/4700 scaling:
    driver: intel_pstate governor: performance cores: 1: 4174 2: 3367 3: 4499
    4: 4424 5: 4550 6: 4539 7: 4283 8: 4558 bogomips: 48000
  Type: itlb_multihit status: KVM: Split huge pages
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
    prctl and seccomp
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0
    chip-ID: 8086:3e98 class-ID: 0300
  Device-2: Microdia USB Live camera type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-1.2:7 chip-ID: 0c45:636b
    compositor: kwin_x11 driver: X: loaded: modesetting unloaded: vesa
    alternate: fbdev,intel gpu: i915 display-ID: :0 screens: 1
    s-diag: 1055mm (41.54")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: VG27AQ1A
    serial: <filter> built: 2020 res: 1920x1080 hz: 120 dpi: 82 gamma: 1.2
    size: 596x336mm (23.46x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,left
    model: Samsung S24B300 serial: <filter> built: 2013 res: 1920x1080 hz: 60
    dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
    22.1.7 direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 1-1.2:7 chip-ID: 0c45:636b
    bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:a2f0 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.68-1-lts running: yes
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
  Device-2: Realtek 802.11ac NIC type: USB driver: rtl8821cu
    bus-ID: 1-1.1:4 chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u1u1 state: down mac: <filter>
    driver: btusb v: 0.8 bus-ID: 1-2.2:9 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 2.26 TiB used: 805.66 GiB (34.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
    type: SSD serial: <filter> rev: K1B3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120
    type: HDD rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
  ID-1: / raw-size: 58.83 GiB size: 58.83 GiB (100.00%) used: 35.81 GiB
    (60.9%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 37.1 MiB
    (38.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 58.83 GiB size: 58.83 GiB (100.00%) used: 35.81 GiB
  ID-4: /var/log raw-size: 58.83 GiB size: 58.83 GiB (100.00%) used: 35.81
    GiB (60.9%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-5: /var/tmp raw-size: 58.83 GiB size: 58.83 GiB (100.00%) used: 35.81
  ID-1: swap-1 type: zram size: 15.49 GiB used: 2.39 GiB (15.4%)
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 347 Uptime: 23h 17m wakeups: 1 Memory: 15.49 GiB used: 10.33 GiB
  (66.7%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1910
  libs: 409 tools: pamac,paru,yay Shell: fish v: 3.5.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.7-1):
  System install date:     2022-09-12
  Last full system update: 2022-09-19
You don’t have those crappy colors (I admit your screenshots look bad! :frowning: ) outside of SystemSettings/SystemTray?
So you open up Dolphin, Web browser, etc. and no issue there?
I believe you have 2 monitors with different DPIs and potentially scalings.
What if you move the SystemSettings window to the other monitor, does it still display bad contrast?
Dolphin looks great, and so does Firefox and all my other apps.
I have two monitors with different resolution and refresh rate, but the same scaling, which is 100%.
I just moved the SystemSettings window to the other monitor, and it looks the same as on the main monitor.
It's been like that forever or before it worked fine and then after "something" that happened on the machine that you may not know the contrast started to crap up?
You are free to trash this whole thread after you read my answer......
I installed Garuda Xfce like a week ago. Everything worked as expected. Then I installed Plasma desktop on top of it, a couple days ago (with X11, not Wayland) and the problem was there right away.
Actually that's very interesting to know!
I'm not an expert of multiple DMs installed or upgrading from one to another, but I remember reading that having multiple DMs can cause all sort of weird issues.
If you really want to make this work, I'm hoping someone with more knowledge would help.
If you don't need Xfce, one obvious option would be to trash your installation and restart fresh with Plasma. :smiley: But you know that one already for sure.
Good point.
If you make such interventions to the system and don’t mention it in the first post, it’s a waste of time from those who want to help.
Just closed.
