I've noticed a request to check and merge is there anything to be concerned abut with that message? Overall the system runs fime. Thanks
(7/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nohang/nohang-desktop.conf.pacnew
/etc/pamac.conf.pacsave
/etc/systemd/homed.conf.pacnew
Please check and merge
Nothing to worry about, but something to take care of at some point:
About what I figured. That list is short compared to the list my roommate gets, but all of our software is running fine.
tbg
17 December 2020 03:56
#4
Occasionally, (but very rarely) if you don't update the file immediately it could result in a broken boot or an inability to login.
How would I get a complete list of programs I let the system build? I know right now Sonarr, Radarr, Lidarr, and Jackett I have no choice but to build if I want them, but I'd bett bottom dollar anything else built can be replaced with a regaular installer, Flatpak, or Snap.
pacman -Qm
will show a list of packages installed which are not in the repositories.
