Pixelated font and titlebar buttons
I’m having this issue where on my second monitor the titlebar font and buttons appear pixelated, not only there but the text in general on this monitor is way off.
I’ve been trying to fix this and play with the settings but found no solution :frowning:
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d0a00734-65df-4c62-b206-4a1ada5e53f2 rw rootflags=subvol=@
quiet resume=UUID=ee425d7f-db9d-4f14-ad8c-bcdf224d9ffb loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Dell product: XPS 15 9570 v: N/A
Mobo: Dell model: 0D0T05 v: A00 serial: <superuser required> UEFI: Dell
v: 1.27.0 date: 08/12/2022
ID-1: BAT0 charge: 5.0 Wh (100.0%) condition: 5.0/56.0 Wh (8.9%) volts: 12.3
min: 11.4 model: BYD DELL CP6DF89 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3470 high: 4077 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3961 3: 3909
4: 4066 5: 4044 6: 4049 7: 3959 8: 3931 9: 3997 10: 4077 11: 4047 12: 800
bogomips: 52799
ports: active: DP-3,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
status: current (as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6
chip-ID: 0c45:671d class-ID: 0e02
gpu: i915,nvidia d-rect: 3590x1080 display-ID: 0
Monitor-1: DP-3 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1670x939 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
inactive: device-2
GT2) device-ID: 8086:3e9b memory: 7.23 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 Ti with Max-Q Design
driver: nvidia v: 545.29.06 device-ID: 10de:1c8c
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 3b:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
Local Storage: total: 238.47 GiB used: 45.22 GiB (19.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
fw-rev: AADA4106 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 45.22 GiB (19.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 7.4 GiB used: 676.2 MiB (8.9%) priority: 100
System Temperatures: cpu: 84.0 C pch: 45.0 C mobo: N/A
Processes: 298 Uptime: 3h 16m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.4 GiB used: 5.39 GiB (72.8%) Init: systemd v: 255
pm: pacman pkgs: 1396 libs: 430 tools: octopi,paru,yay Shell: fish v: 3.6.2
Garuda (2.6.19-2):
System install date:     2023-11-14
Last full system update: 2023-12-09 ↻
Relevant software:       timeshift(custom) NetworkManager dracut nvidia-dkms
Does rebooting help?
No, i’ve been having this problem for a month or so(since attaching the 2nd monitor) and rebooted multiple times
Does it do it running x11 instead of wayland?
idk how can i check? (im sorry im a newbie)
restart and choose x11 at the login screen on the lower left tab
Thanks! That fixed the problem
But now when i change the global scale of a monitor it applies even for the second one :frowning:
Before i had my first monitor tset at 115% and the second at 100%, now i cant do that, they’re aither both at 100% or both at 125%
You can check that in the inxi output.
