inxi
inxi -Faz
System: Kernel: 5.15.2-217-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds-generic_v3
root=UUID=ef15347e-a4da-4628-afc3-2bff20cbb710 rw rootflags=subvol=@ quiet nvidia-drm.modeset=1 splash
resume=UUID=e7745511-30a0-4b3d-93c1-4bc3daa8b2b8 loglevel=3 sysrq_always_enabled=1 nowatchdog
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASRock model: X470 Taichi serial: <filter> UEFI: American Megatrends v: P4.20
date: 07/22/2020
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
Device-2: ps-controller-battery-a0:ab:51:90:7e:70 model: N/A serial: N/A charge: N/A status: Charging
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86488
Speed: 4077 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4077 2: 4091 3: 4019 4: 4099 5: 4093
6: 4090 7: 4092 8: 4068 9: 3611 10: 4121 11: 4072 12: 3715
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 0e:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 6400x2160 s-dpi: 102 s-size: 1594x543mm (62.8x21.4") s-diag: 1684mm (66.3")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 52 size: 1872x1053mm (73.7x41.5") diag: 2148mm (84.6")
Monitor-2: DP-0 res: 2560x1080 dpi: 81 size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 0e:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 10:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Sony Wireless Controller type: USB driver: playstation,snd-usb-audio,usbhid bus-ID: 1-1.3:6
chip-ID: 054c:0ce6 class-ID: 0300
Sound Server-1: ALSA v: k5.15.2-217-tkg-pds running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:7 chip-ID: 8087:0aa7
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Drives: Local Storage: total: 2.27 TiB used: 2.77 TiB (121.6%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 31.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
Partition: ID-1: / raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 137.06 GiB (63.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 563 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:6
ID-3: /home raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 137.06 GiB (63.6%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:7
ID-4: /var/log raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 137.06 GiB (63.6%) fs: btrfs
ID-5: /var/tmp raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 137.06 GiB (63.6%) fs: btrfs
Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 17.18 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 15.61 GiB used: 1.07 GiB (6.8%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 52.1 C mobo: 36.0 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1295 fan-3: 1307 fan-4: 1513 fan-5: 1193 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.28
Info: Processes: 466 Uptime: 16m wakeups: 3 Memory: 15.61 GiB used: 9.84 GiB (63.0%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2216 lib: 566 flatpak: 0 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: alacritty inxi: 3.3.08
So I noticed that recently (Im guessing after a pipewire update don't know which) audio recording with pulse via pipewire is broken ( so apps like obs and simple screen recorder no longer are able to caputre audio) anyone else run into this?
for example simple screen recorder crashes with this
simplescreenrecorder
==================== SSR started ====================
SimpleScreenRecorder 0.4.3
Compiled with GCC 10.2.0
Qt: header 5.15.2, lib 5.15.2
libavformat: header 58.45.100, lib 58.76.100
libavcodec: header 58.91.100, lib 58.134.100
libavutil: header 56.51.100, lib 56.70.100
libswscale: header 5.7.100, lib 5.9.100
[CPUFeatures::Detect] CPU features: mmx sse sse2 sse3 ssse3 sse4_1 sse4_2 avx avx2 bmi1 bmi2
[ScreenScaling] Detected fractional screen scale factor, scaling was disabled.
Icon theme "gnome" not found.
[ALSAInput::GetSourceList] Generating source list ...
[ALSAInput::GetSourceList] Found plugin: [pipewire] PipeWire Sound Server
[ALSAInput::GetSourceList] Found card: [hw:0] Loopback
[ALSAInput::GetSourceList] Found device: [hw:0,0] Loopback: Loopback PCM
[ALSAInput::GetSourceList] Found device: [hw:0,1] Loopback: Loopback PCM
[ALSAInput::GetSourceList] Found card: [hw:1] HDA NVidia
[ALSAInput::GetSourceList] Found card: [hw:2] HD-Audio Generic
[ALSAInput::GetSourceList] Found device: [hw:2,0] HD-Audio Generic: ALC1220 Analog
[ALSAInput::GetSourceList] Found device: [hw:2,2] HD-Audio Generic: ALC1220 Alt Analog
[ALSAInput::GetSourceList] Found card: [hw:3] Wireless Controller
[ALSAInput::GetSourceList] Found device: [hw:3,0] Wireless Controller: USB Audio
[PulseAudioInput::GetSourceList] Generating source list ...
[SourceNamesCallback] Found source: [alsa_output.pci-0000_0e_00.1.hdmi-stereo.monitor] Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI)
[PageRecord::StartPage] Starting page ...
[PageRecord::StartPage] Started page.
[PageRecord::StartOutput] Starting output ...
[Muxer::Init] Using format mp4 (MP4 (MPEG-4 Part 14)).
[Muxer::AddStream] Using codec libx264 (libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10).
[VideoEncoder::PrepareStream] Using pixel format nv12.
[libx264 @ 0x55d6cf700e00] using SAR=1/1
[libx264 @ 0x55d6cf700e00] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
[libx264 @ 0x55d6cf700e00] profile High, level 5.1, 4:2:0, 8-bit
[libx264 @ 0x55d6cf700e00] 264 - core 163 r3060 5db6aa6 - H.264/MPEG-4 AVC codec - Copyleft 2003-2021 - http://www.videolan.org/x264.html - options: cabac=1 ref=16 deblock=1:0:0 analyse=0x3:0x133 me=umh subme=10 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=24 chroma_me=1 trellis=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=8 b_pyramid=2 b_adapt=2 b_bias=0 direct=3 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=60 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[Muxer::AddStream] Using codec libvorbis (libvorbis).
[AudioEncoder::PrepareStream] Using sample format f32p.
[BaseEncoder::EncoderThread] Encoder thread started.
[Muxer::MuxerThread] Muxer thread started.
[PageRecord::StartOutput] Started output.
[Synchronizer::SynchronizerThread] Synchronizer thread started.
[PageRecord::StartInput] Starting input ...
[X11Input::Init] Using X11 shared memory.
[X11Input::InputThread] Input thread started.
[PulseAudioConnectStream] Error: Stream connection attempt failed! Reason: Input/Output error
[PageRecord::StartInput] Error: Something went wrong during initialization.
[X11Input::~X11Input] Stopping input thread ...
[X11Input::InputThread] Input thread stopped.
[PageRecord::StopOutput] Stopping output ...
[PageRecord::StopOutput] Stopped output.
[PageRecord::StopPage] Stopping page ...
[Synchronizer::~Synchronizer] Stopping synchronizer thread ...
[Synchronizer::SynchronizerThread] Synchronizer thread stopped.
[Muxer::~Muxer] Stopping encoders ...
[Muxer::~Muxer] Waiting for muxer thread to stop ...
[BaseEncoder::EncoderThread] Encoder thread stopped.
[Muxer::MuxerThread] Muxer thread stopped.
[BaseEncoder::~BaseEncoder] Stopping encoder thread ...
[PageRecord::StopPage] Stopped page.
==================== SSR stopped ====================
