first do: sudo pacman -S lib32-pipewire-jack
then: sudo pacman -S pipewire-jack
suggested here:
https://forum.garudalinux.org/t/everything-about-packages/26/197?u=ankur
suggested here:
All, please consider that the solution is already marked above and seems to be working (at least that worked for me).
I suggest using that at first, avoiding other routes, especially removing other packages or lib32 libraries that you might need in the future, and reporting possible issues found following that solution.
hi, a conflict that came up when i tried to do a system upgrade. what can i do to fix it, as i feel like if i uninstall either of this it will mess up media stuff.
the error:
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jack2 and pipewire-jack are in conflict
inxi -Faz command
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d98179c7-5527-4f22-be10-24e782aa5545 rw rootflags=subvol=@
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0FGN4M v: A00 serial: <filter> UEFI: Dell v: 2.9.0
date: 01/17/2019
ID-1: BAT0 charge: 29.4 Wh (100.0%) condition: 29.4/41.4 Wh (71.0%)
volts: 16.9 min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i3-6006U socket: BGA1356 (U3E1) note: check
bits: 64 type: MT MCP arch: Skylake family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2000 min/max: 400/2000 base/boost: 2000/2000 scaling:
driver: intel_pstate governor: performance volts: 0.8 V ext-clock: 100 MHz
cores: 1: 2000 2: 2000 3: 2000 4: 2000 bogomips: 15999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:6a05 class-ID: 0e02
Display: server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) unloaded: modesetting
failed: intel alternate: fbdev,vesa display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 01:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 0cf3:e009 class-ID: e001
address: <filter>
Local Storage: total: 1.02 TiB used: 20.46 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT120BX500SSD1
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-1: / raw-size: 123.87 GiB size: 123.87 GiB (100.00%)
used: 20.43 GiB (16.5%) fs: btrfs block-size: 4096 B dev: /dev/sda5
maj-min: 8:5
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 30.7 MiB (32.3%) fs: vfat block-size: 512 B dev: /dev/sdb2
maj-min: 8:18
ID-3: /home raw-size: 123.87 GiB size: 123.87 GiB (100.00%)
maj-min: 8:5
ID-4: /var/log raw-size: 123.87 GiB size: 123.87 GiB (100.00%)
maj-min: 8:5
ID-5: /var/tmp raw-size: 123.87 GiB size: 123.87 GiB (100.00%)
maj-min: 8:5
ID-1: swap-1 type: zram size: 3.57 GiB used: 996.5 MiB (27.2%)
System Temperatures: cpu: 47.0 C pch: 47.5 C mobo: 47.0 C
Fan Speeds (RPM): cpu: 0
Processes: 251 Uptime: 12m wakeups: 1 Memory: 3.57 GiB
used: 2.71 GiB (75.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1477 pacman: 1467 lib: 487 flatpak: 10
Shell: Bash (su) v: 5.1.16 running-in: yakuake inxi: 3.3.11
worked for me like a charm
try with that sudo pacman -Syu pipewire-jack lib32-pipewire-jack
and welcome to the forum!
It's weird how this works for some people but not others - did you have pipewire-support
installed?
i think i did, i mean, i reinstalled garuda last week and pipewire came preinstalled this time, i have the pipewire-support
installed now tho
Conflict here as well...however I select N and my system is working fine for me. At least so far. Audio is working and everything else so it hasn't effected me.
When I try to run the first command of the solution it's asking to remove lib32-jack2:
:: lib32-pipewire-jack and lib32-jack2 are in conflict (lib32-jack). Remove lib32-jack2? [y/N] n
Is this intended behavior to fix this issue?
Yes.
Tried the above methods, none works as of now still the "packages are in conflict" message is displayed..
If none of the above methods work then you have a different problem.
Replacing the packages or removing then reinstalling will work.
Post the commands youâre using and their output if youâd like someone to try to help.
i mean i didnt try removing 32 libs directly(use wine for old games like roadrash and stuff), tried removing jack2 but still it wont since dependencies
Yup fixed it for me too. Thanks
I selected Y and it removed Jack2 and proceeded with install âŚall seems well after reboot.
This could be a âcorrectâ conflict. Let me check upstream.
Edit: This is correct behaviour - PipeWire does not provide the functionality of jack2-dbus
so you canât use it as a drop-in replacement. In this case you should continue to use JACK2.
However, to have jack2-dbus
on your system you must have installed something that requires it, so youâd know what that thing is (e.g. Cadence).
When i try to use that command i get this output from the konsole:
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
warning: lib32-pipewire-jack-1:0.3.43-4 is up to date -- reinstalling
warning: garuda-settings-manager-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106
-1)
warning: garuda-settings-manager-kcm-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c
4106-1)
:: Replace hwids with core/hwdata? [Y/n]
:: pipewire-jack and jack2 are in conflict
Just did a fresh install of Garuda KDE using the latest ISO and after landing on the desktop and tell it yes I wanted to do the updates they get so far and I get greed with jack2 and pipewire-jack being in conflict. I had to grab my phone and ask in Telegram there how to deal with it. It's fixed now but why wouldn't of this been resolved before I ever got to the desktop, and tried to do updates? Thanks
EDIT:
At least I think it's solved. I won't know for sure till I go back into Manjaro and see if I have sound cause I remove both jack2 and lib32-jack2.
Yes, I just tried and it worked i typed in console: "sudo pacman -R pipewire-jack lib32-pipewire-jack pipewire-support" and that cleared up the issue for me!!
Thanks mate worked a treat honestly it seems to be a recurring issue but your fix Nailed it. If you're ever in Australia I owe you a beer cheers Lou
