I really liked garuda, but i can't use it because i play rocksmith which i was able to play using cadence. I tried uninstalling pipewire and revert to the same audio server manjaro uses, unfortunately cadence wasn't detecting any audio devices so i had to revert back to manjaro for now. Other than that i liked everything about it, but i don't know what all to do to get cadence to detect audio devices so i gave up. I hear pipewire is better, but still new so it ain't well supported yet.
Pretty sure it would work with the correct combination of packages, but if Manjaro works for you then great.
Btw..... Garuda assistant allows changing to Pulseaudio by simply checking a box.
