PipeWire doesn't recognize audio device
I’ve installed Garuda Dragonized yesterday, it’s working fine except that i have no audio because pipewire does not seem to recognize my audio device. I’ve tried most things i’ve found in the forums with no help. I had this issue on Windows as well when i just installed it, but i only had to install the drivers from there then unplug then plug my headphones back in, then it worked. I have tried re-plugging my headphones on Garuda as well, did not work. ALSA does seem to recognize my audio device (ALC887) VD but not pipewire.
inxi output:
Kernel: 6.14.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=df3ef74e-6819-4153-9575-25dd340a582b rw rootflags=subvol=@
quiet snd_hda_intel.dmic_detect=0 snd-intel-dspcfg.dsp_driver=1
resume=UUID=736adc79-f2ef-4789-9b7d-9e952713373d loglevel=3 ibt=off
Type: Desktop System: issx-1230 product: issx-28652 v: issx-20593
serial: <superuser required> Chassis: issx-32095 type: 3 v: issx-20563
Mobo: issx-4316 model: issx-18776 v: issx-13769
serial: <superuser required> part-nu: issx-1062 uuid: <superuser required>
UEFI: issx-2265 v: issx-7631 date: 10/14/2016
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 27199
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: DVI-D-1
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled model: Asus VS247
serial: <filter> built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 570.144 device-ID: 10de:1c82
bits) driver: mesa llvmpipe v: 25.0.4-arch1.1 (LLVM 19.1.7)
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
API: ALSA v: k6.14.3-zen1-1-zen status: kernel-api with: aoss
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 931.51 GiB used: 15.21 GiB (1.6%)
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 77.88 GiB size: 77.88 GiB (100.00%)
used: 15.21 GiB (19.5%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 894.7 MiB size: 892.9 MiB (99.80%)
used: 612 KiB (0.1%) fs: vfat dev: /dev/sda8 maj-min: 8:8
ID-3: /home raw-size: 77.88 GiB size: 77.88 GiB (100.00%)
ID-4: /var/log raw-size: 77.88 GiB size: 77.88 GiB (100.00%)
ID-5: /var/tmp raw-size: 77.88 GiB size: 77.88 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
ID-2: swap-2 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 55.0 C mobo: N/A
Memory: total: 16 GiB available: 15.57 GiB used: 2.73 GiB (17.5%)
Processes: 286 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: org_kde_powerdevil,
Packages: 1337 pm: pacman pkgs: 1325 libs: 379 tools: octopi,paru
pm: flatpak pkgs: 12 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
System install date:     2025-04-21
Last full system update: 2025-04-23
Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
‘aplay -l’ output:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
‘pactl list short sinks’ output:
35      auto_null       PipeWire        float32le 2ch 48000Hz   SUSPENDED
Does the audio work in a live USB?
If so, you could try:
  • installing and booting with the linux-lts kernel (in the case this should be a kernel regression bug)
  • downgrading pipewire, to check if this is a pipewire regression
downgrade pipewire
  • Then you could also check if this is occurring also if you switch to pulseaudio. You can do this in RANI system settings. I’m not on my Garuda machine at the moment, but, if I remember correctly, you simply have to use the “Pulseaudio support” flag instead of the “Pipewire support” (default) and probably you should flag also “Alsa support” and “Jack support”. Take a note of what you have now, in case you need/want to go back to it.
The audio does not appear to work in a live USB.
If so, I’d try with pulseaudio…
I tried with pulseaudio as well, still not finding my device.
Here is the output of ‘pactl list short sinks’ with pulseaudio:
0       auto_null       module-null-sink.c      s16le 2ch 48000Hz       SUSPENDED
If you dual boot with Windows, make sure you completely shut down when you are in Windows, disabling the “fast startup” feature. What Is “Fast Startup” Mode and How to Enable or Disable It? - MiniTool
Also a cold boot might help in this case.
I’m dual booting with Windows 11, and have already disabled ‘hibernation’ and stuff like that. I’ve tried cold booting and it still hasnt detected my audio device.
Another information, the microphone on my headphones are detected and works. Just not the output.
The Realtek ALC887-VD is always problematic on Linux, especially as it is usually caused by a faulty BIOS.
In addition, you have an ancient BIOS and I can’t find anything useful about this hardware.
Remove these kernel parameters, if I am not mistaken they are deprecated and no longer work on new kernels. Then reboot and then open a terminal and try this:
sudo tee /etc/modprobe.d/snd-hda-intel-fix.conf <<<'options snd-hda-intel probe_mask=1'
Then reboot again and check if the sound works w/o issues.
it turns out i plugged in my headphones in the wrong port :person_facepalming:
i have no idea why it worked on windows but i thought it was a linux issue, turns out it was just mine. thanks for the help though!
The main problem is usually about 60 cm in front of the screen. :sweat_smile:
the ports are actually in the back of the PC case so i think that explains how i could’ve missed that :rofl:
I think it is because it is a headset and not headphones. The fact that it works on windows is probably because Realtek has coded the windows drivers correctly so that it works on the appropriate port. But Realtek drivers are bad on Linux anyway.
I have marked your post as solution, maybe it will help one or the other with the same hardware/sound chip and/or a similar issue.
Have fun with Garuda Linux. :slightly_smiling_face:
