Hello!
λ inxi -Fza
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b24f311b-7627-4dc9-9b5a-182829379e69 rw [email protected]
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: Gigabyte model: B365M H v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3
date: 09/05/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 2798 high: 3625 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3548 2: 2000 3: 3266
4: 2188 5: 2163 6: 3625 bogomips: 34798
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f82 class-ID: 0300
Device-2: GEMBIRD USB2.0 PC CAMERA type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2 chip-ID: 1908:2310
class-ID: 0102
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1680x1050 s-dpi: 90 s-size: 474x303mm (18.7x11.9")
s-diag: 563mm (22.1")
Monitor-1: DP-0 res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
Device-3: GEMBIRD USB2.0 PC CAMERA type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Integrated System Solution Bluetooth Device type: USB
driver: btusb v: 0.8 bus-ID: 1-9:7 chip-ID: 1131:1004 class-ID: fe01
Local Storage: total: 1.64 TiB used: 710.81 GiB (42.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: B1D2 scheme: GPT
model: WD5000AZRX-00A8LB0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
model: WD10EZEX-60WN4A1 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A03 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB model: Specific STORAGE DEVICE
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0009 scheme: MBR
ID-1: / raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
used: 21.24 GiB (31.1%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 25.6 MiB (26.6%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-4: /var/log raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nvidia temp: 44 C
Processes: 313 Uptime: 3h 14m wakeups: 0 Memory: 15.57 GiB
used: 5.64 GiB (36.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1369 lib: 342 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
λ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 223,6G 0 disk
├─sda1 8:1 0 529M 0 part
├─sda2 8:2 0 100M 0 part /boot/efi
├─sda3 8:3 0 16M 0 part
├─sda4 8:4 0 154,6G 0 part /run/media/catalin/8A5602B95602A5D3
└─sda5 8:5 0 68,4G 0 part /var/tmp
/var/log
/var/cache
/srv
/root
/home
sdb 8:16 0 465,8G 0 disk
├─sdb1 8:17 0 100M 0 part
├─sdb2 8:18 0 172,7G 0 part /mnt/4C42178042176DC8
├─sdb3 8:19 0 146,5G 0 part /mnt/9440CC3240CC1CBC
└─sdb4 8:20 0 146,5G 0 part /mnt/62D2D04CD2D025D7
sdc 8:32 0 931,5G 0 disk
├─sdc1 8:33 0 512M 0 part
├─sdc2 8:34 0 462,3G 0 part /mnt/80DE4F00DE4EEDCA
└─sdc3 8:35 0 468,8G 0 part /mnt/6EE25599E255667D
sdd 8:48 1 58,6G 0 disk
├─sdd1 8:49 1 58,6G 0 part /mnt/usb-Specific_STORAGE_DEVICE_19090601010022-0:0-part1
└─sdd2 8:50 1 32M 0 part /mnt/usb-Specific_STORAGE_DEVICE_19090601010022-0:0-part2
zram0 254:0 0 15,6G 0 disk [SWAP]
My issue: I don't have permission to write/delete on my USB flashdrive.
As you probably already know, I have a laptop which needs a Linux OS on it and since it's a problematic computer (in terms of hardware), I thought to give it a try with some distros that are systemd-free (according to someone).
On this PC I have dual-boot with Windows10 but slowly and surely I want to quit it forever. So I tried all day learning and searching the forums on how I can put / copy-paste some ISOs on my Hama 3.0 USB flashdrive (which is exfat with Ventoy). Eventually I managed to copy them from Downloads to /mnt/usb-Specific_STORAGE_DEVICE_19090601010022-0:0-part1/ (which is /dev/sdd1) with the command sudo cp /path/to/file /path/to/destination.
I also tried changing the permission by right clicking or going for 1. su 2. Chown -v username foldername but then I learned this is not a normal file or directory, but a.. separate drive.
I still cannot delete them, copy paste with mouse or drag&drop. I am the only user and administrator.
[Screenshot-7 — ImgBB](Link 1)
[Screenshot-5 — ImgBB](Link 2)
Regarding the mounting.. since I`m newbie.. I installed gnome-disk-utility to have them auto-mounted at startup (and then I learned it's not really okay like this as they have to be mounted somewhere else and not in /mnt/ which is a temporary directory, right?)
Then I learned my problem is correlated with fstab and uid, gid, and umask. But I don't know exactly what I have to do in my case. I understood that it would be better to have all my drives and partitions mounted somewhere else, like in /root/.
I searched and read on many Arch Linux posts but they tend to get so specific and technical.. Unfortunately, I could not find a graphical way of resolving this one.
What do you think I should do?
