Performance issues with wine and proton
I have been having massive performance issues while using proton and wine for the past few days. Game windows dont show up despite the process being there, shaders taking way too long to compile, stutters, etc.
Edit: Did a bit more messing around and issues happen the most when im rendering stuff
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=376a43ca-820c-4714-8095-7da9562714b2 rw rootflags=subvol=@
intel_pstate=passive quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=5df3a12e-4732-4ef6-859a-ade78bf370aa loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: GAME GARAJ product: TRACER XL v: REV:1.0
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: GAME GARAJ model: TRACER XL v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17F5IE2.100 date: 01/22/2021
ID-1: BAT1 charge: 42.1 Wh (95.9%) condition: 43.9/51.3 Wh (85.5%)
volts: 12.8 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-10750H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3285 high: 5000 min/max: 800/5000 base/boost: 2475/8300
scaling: driver: intel_cpufreq governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 4258 2: 800 3: 1326 4: 800 5: 4577 6: 4559
7: 4305 8: 4074 9: 4504 10: 4422 11: 800 12: 5000 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 535.113.01
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x978f built: 2020
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 535.113.01
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: n/a (root, process) with:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 2.27 TiB used: 1.91 TiB (83.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z44101 temp: 39.9 C
SMART: yes health: PASSED on: 361d 8h cycles: 2,384
read-units: 103,381,242 [52.9 TB] written-units: 68,006,521 [34.8 TB]
model: WD20JDRW-11C7VS0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 4800 serial: <filter>
fw-rev: 1034 drive-rev: 01.01A01 temp: 44 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 76d 0h cycles: 74
ID-1: / raw-size: 419.92 GiB size: 419.92 GiB (100.00%)
used: 341.94 GiB (81.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 419.92 GiB size: 419.92 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 419.92 GiB size: 419.92 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 419.92 GiB size: 419.92 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.45 GiB used: 164.2 MiB (1.0%)
ID-2: swap-2 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 71.0 C pch: 65.0 C mobo: N/A gpu: nvidia
temp: 62 C
Processes: 373 Uptime: 1h 30m wakeups: 1 Memory: total: 16 GiB
available: 15.45 GiB used: 7.2 GiB (46.6%) igpu: 64 MiB Init: systemd v: 254
Packages: 2377 pm: pacman pkgs: 2362 libs: 619 tools: octopi,paru
pm: flatpak pkgs: 15 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
Garuda (2.6.17-1):
System install date:     2023-10-03
Last full system update: 2023-10-06
Same here. The latest proton update (8.0-4) messed everything up. Game starting with brutal lag, and then freezing. (Proton GE too…) None of my games working fullscreen anymore just in windowed mode. At least for me fullscreen working fine with proton 7.
