PC gets stuck during shutdown
Kernel: 6.1.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c8741d8f-8170-48c1-ba80-1f9ce9aba345 rw rootflags=subvol=@
resume=UUID=cca75226-3fcb-4d17-89c3-3452f2f11079 loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: X299 UD4 Pro v: N/A
Mobo: Gigabyte model: X299 UD4 Pro-CF serial: <superuser required>
UEFI: American Megatrends v: F9 date: 06/17/2022
Info: model: Intel Core i9-9820X bits: 64 type: MT MCP arch: Skylake
gen: core 9 level: v4 note: check process: Intel 14nm family: 6
model-id: 0x55 (85) stepping: 4 microcode: 0x2006F05
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 10 MiB desc: 10x1024 KiB
L3: 16.5 MiB desc: 1x16.5 MiB
Speed (MHz): avg: 3872 high: 4001 min/max: 1200/4100:4200 scaling:
driver: intel_pstate governor: performance cores: 1: 3778 2: 4000 3: 3975
4: 4000 5: 4000 6: 4000 7: 3920 8: 4000 9: 4000 10: 3765 11: 4000 12: 4000
13: 3783 14: 4000 15: 3753 16: 3300 17: 3875 18: 4000 19: 4001 20: 3300
bogomips: 132059
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: ASUSTeK driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 65:00.0 chip-ID: 10de:1e04 class-ID: 0300
Screen-1: 0 s-res: 2560x2160 s-dpi: 80 s-size: 813x686mm (32.01x27.01")
s-diag: 1064mm (41.88")
Monitor-1: DP-0 pos: primary,bottom res: 2560x1080 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
Monitor-2: DP-2 pos: top res: 2560x1080 dpi: 82
size: 797x334mm (31.38x13.15") diag: 864mm (34.02") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA TU102 High Definition Audio vendor: ASUSTeK
bus-ID: 65:00.1 chip-ID: 10de:10f7 class-ID: 0403
API: ALSA v: k6.1.32-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: b3:00.0
IF: wlp179s0 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:5 chip-ID: 8087:0aa7
Local Storage: total: 6.39 TiB used: 2.99 TiB (46.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MD04ACA600
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: FS2A scheme: GPT
ID-1: / raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
used: 383.19 GiB (41.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-4: /var/log raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.16 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.04 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 403 Uptime: 6m wakeups: 1 Memory: available: 31.04 GiB
used: 5.81 GiB (18.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2288 libs: 587 tools: octopi,pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.27
System install date:     2022-04-20
Last full system update: 2023-06-07
Hello everyone, hope you all are well.
My issue is most of the time when shutting down my PC, either from the shutdown command or the gui shutdown button, my PC gets stuck on the text screen (not sure what the screen is called but it shows unmounting drives, etc) and power never turns off.
I have tried:
  • updating the OS -- i do this every few days anyway
  • updating my bios to the latest release
I'm not sure which log shows the shutdown process but just from watching I don't see anything that sticks out immediately.
You may try with journalctl -b -1 -n100 after a failed shutdown to see the last 100 (-n100, adjust as necessary) journal messages from the last boot (-b -1) -- or -b -1 -r to see them all in reverse order.
Not everything is logged there, as after a certain point in the shutdown there's nowhere to write anything, but hopefully there will be some indication of failure.
If possible, also try to read and post here the last messages on the text screen ("console"), and this is a case where a picture of the screen won't be frowned upon as long as it's readable.
I'm trying to find something online that rings a bell, so far I only found old issues that shouldn't be relevant anymore.
If you noticed some pattern to the "most of the time", that may (or may not) hint at the cause (a silly example: it only hangs when some peripheral is connected).
Another troubleshooting step, is trying some other kernel.
I'm thinking this could be a problem with the motherboard ACPI implementation, and perhaps there is a kernel parameter that can work around it. Gotta read some more.
thanks so much for the reply. Here’s the return of the journalctl command:
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1408] dhcp6 (enp0s31f6): activation: beginn>
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1408] dhcp6 (enp0s31f6): state changed no l>
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1412] manager: NetworkManager state is now >
Jun 07 20:55:56 HomeDesktop dbus-daemon[892]: [system] Activating via systemd: service name='org.freedesktop.nm_>
Jun 07 20:55:56 HomeDesktop dbus-daemon[892]: [system] Activation via systemd failed for unit 'dbus-org.freedesk>
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1417] device (wlp179s0): state change: unav>
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1419] device (wlp179s0): set-hw-addr: reset>
Jun 07 20:55:56 HomeDesktop NetworkManager[952]: <info>  [1686160556.1470] exiting (success)
Jun 07 20:55:56 HomeDesktop systemd[1]: NetworkManager.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Network Manager.
Jun 07 20:55:56 HomeDesktop systemd[1]: NetworkManager.service: Consumed 4.293s CPU time.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopping D-Bus System Message Bus...
Jun 07 20:55:56 HomeDesktop systemd[1]: dbus.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped D-Bus System Message Bus.
Jun 07 20:55:56 HomeDesktop systemd[1]: dbus.service: Consumed 7.761s CPU time.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Basic System.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Path Units.
Jun 07 20:55:56 HomeDesktop systemd[1]: grub-btrfs-snapper.path: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Monitors for new snapshots.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Slice Units.
Jun 07 20:55:56 HomeDesktop systemd[1]: Removed slice Virtual Machine and Container Slice.
Jun 07 20:55:56 HomeDesktop systemd[1]: Removed slice User and Session Slice.
Jun 07 20:55:56 HomeDesktop systemd[1]: user.slice: Consumed 2h 7min 54.700s CPU time.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Socket Units.
Jun 07 20:55:56 HomeDesktop systemd[1]: avahi-daemon.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: cups.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed CUPS Scheduler.
Jun 07 20:55:56 HomeDesktop systemd[1]: dbus.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed D-Bus System Message Bus Socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: libvirtd-admin.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Libvirt admin socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: libvirtd-ro.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Libvirt local read-only socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: libvirtd.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Libvirt local socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: saned.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed saned incoming socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-oomd.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Userspace Out-Of-Memory (OOM) Killer Socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: virtlockd.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Virtual machine lock manager socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: virtlogd.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Virtual machine log manager socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target System Initialization.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Local Encrypted Volumes.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Local Integrity Protected Volumes.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Local Verity Protected Volumes.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopping Set Up Additional Binary Formats...
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Apply Kernel Variables.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Closed Process Core Dump Socket.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Load Kernel Modules.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopping Network Time Synchronization...
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-update-done.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Update is Completed.
Jun 07 20:55:56 HomeDesktop systemd[1]: ldconfig.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Rebuild Journal Catalog.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jun 07 20:55:56 HomeDesktop systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfull>
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Network Time Synchronization.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-binfmt.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Set Up Additional Binary Formats.
Jun 07 20:55:56 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount >
Jun 07 20:55:56 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jun 07 20:55:56 HomeDesktop systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped Create Volatile Files and Directories.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopped target Local File Systems.
Jun 07 20:55:56 HomeDesktop systemd[1]: mnt-shared.automount: Deactivated successfully.
Jun 07 20:55:56 HomeDesktop systemd[1]: Unset automount mnt-shared.automount.
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /boot/efi...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /home...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /root...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Jun 07 20:55:56 HomeDesktop umount[593790]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount po>
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-vconsole-setup.service...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /srv...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /tmp...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /var/cache...
Jun 07 20:55:56 HomeDesktop systemd[1]: Unmounting /var/tmp...
Jun 07 20:55:56 HomeDesktop umount[593794]: umount: /tmp: target is busy.
Jun 07 20:55:56 HomeDesktop systemd[1]: Stopping Flush Journal to Persistent Storage...
Jun 07 20:55:56 HomeDesktop systemd[1]: boot-efi.mount: Deactivated successfully.
I have not noticed a pattern to this behavior, it has been after updates, not after updates, etc.
I’ll take a pic of the console and post back here
I'm no expert but the journal looks OK to me. Yes, let's see what's printed on the console.
just for reference, here is a journalctl after a successful shutdown. I've just tested it several times and, go figure, it has worked fine :roll_eyes: I'm going to keep trying to replicate this though since it really bugs me...
Jun 08 20:08:17 HomeDesktop systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Network Manager Wait Online.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping Network Manager...
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1516] caught SIGTERM, shutting down normally.
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1712] dhcp4 (enp0s31f6): canceled DHCP transaction
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1712] dhcp4 (enp0s31f6): activation: beginning transaction (timeout in 45 seconds)
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1712] dhcp4 (enp0s31f6): state changed no lease
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1714] dhcp6 (enp0s31f6): canceled DHCP transaction
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1714] dhcp6 (enp0s31f6): activation: beginning transaction (timeout in 45 seconds)
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1714] dhcp6 (enp0s31f6): state changed no lease
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1716] manager: NetworkManager state is now CONNECTED_SITE
Jun 08 20:08:17 HomeDesktop dbus-daemon[867]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-d>
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1718] device (wlp179s0): state change: unavailable -> unmanaged (reason 'unmanaged', s>
Jun 08 20:08:17 HomeDesktop dbus-daemon[867]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activa>
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1720] device (wlp179s0): set-hw-addr: reset MAC address to C8:09:A8:9F:4C:D2 (unmanage)
Jun 08 20:08:17 HomeDesktop NetworkManager[928]: <info>  [1686244097.1770] exiting (success)
Jun 08 20:08:17 HomeDesktop systemd[1]: NetworkManager.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Network Manager.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping D-Bus System Message Bus...
Jun 08 20:08:17 HomeDesktop systemd[1]: dbus.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped D-Bus System Message Bus.
Jun 08 20:08:17 HomeDesktop systemd[1]: dbus.service: Consumed 1.105s CPU time.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Basic System.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Path Units.
Jun 08 20:08:17 HomeDesktop systemd[1]: grub-btrfs-snapper.path: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Monitors for new snapshots.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Slice Units.
Jun 08 20:08:17 HomeDesktop systemd[1]: Removed slice Virtual Machine and Container Slice.
Jun 08 20:08:17 HomeDesktop systemd[1]: Removed slice User and Session Slice.
Jun 08 20:08:17 HomeDesktop systemd[1]: user.slice: Consumed 4min 59.205s CPU time.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Socket Units.
Jun 08 20:08:17 HomeDesktop systemd[1]: avahi-daemon.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: cups.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed CUPS Scheduler.
Jun 08 20:08:17 HomeDesktop systemd[1]: dbus.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed D-Bus System Message Bus Socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: libvirtd-admin.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Libvirt admin socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: libvirtd-ro.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Libvirt local read-only socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: libvirtd.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Libvirt local socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: saned.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed saned incoming socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-oomd.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Userspace Out-Of-Memory (OOM) Killer Socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: virtlockd.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Virtual machine lock manager socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: virtlogd.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Virtual machine log manager socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target System Initialization.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Local Encrypted Volumes.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Local Integrity Protected Volumes.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Local Verity Protected Volumes.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping Set Up Additional Binary Formats...
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Apply Kernel Variables.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Closed Process Core Dump Socket.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Load Kernel Modules.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping Network Time Synchronization...
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jun 08 20:08:17 HomeDesktop systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Network Time Synchronization.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-binfmt.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Set Up Additional Binary Formats.
Jun 08 20:08:17 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jun 08 20:08:17 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jun 08 20:08:17 HomeDesktop systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped Create Volatile Files and Directories.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopped target Local File Systems.
Jun 08 20:08:17 HomeDesktop systemd[1]: mnt-shared.automount: Deactivated successfully.
Jun 08 20:08:17 HomeDesktop systemd[1]: Unset automount mnt-shared.automount.
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /boot/efi...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /home...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /root...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Jun 08 20:08:17 HomeDesktop umount[27540]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount point specified.
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-vconsole-setup.service...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /srv...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /tmp...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /var/cache...
Jun 08 20:08:17 HomeDesktop systemd[1]: Unmounting /var/tmp...
Jun 08 20:08:17 HomeDesktop umount[27544]: umount: /tmp: target is busy.
Jun 08 20:08:17 HomeDesktop systemd[1]: Stopping Flush Journal to Persistent Storage...
Jun 08 20:08:17 HomeDesktop systemd[1]: boot-efi.mount: Deactivated successfully.
Hmm. Which window manager do you use?
I remember having a similiar issue with KDE.
Inxi says it's KDE, indeed I found several reports (though somewhat old). Was that intermittent too?
Yes I'm using KDE
Hmm. I think those cases were somewhat related to either a KDE+wayland-combination or SDDM failing to shut down correctly. When I had it, it could be that it didn't happen for days only to suddenly return. Quite annoying and I think I actually took the ugly solution and made a backup and reinstalled back then...
Ok i replicated the problem. during the time between my previous shut down and this one, I:
-checked this forum, a couple other sites, gmail, etc
-played a game on steam
-watched a video on youtube
Sorry for the quality and format, my screen is ultrawide and the shutdown console doesn't seem to like that
To my knowledge the bottom most thing you see is the kernel output, which means systemd has already stopped at that point. You could try a different kernel.
thanks, ill swap to zen and see how it acts
Still testing here, haven't had too much time in the past few days
Hello, sorry for the delay. I am still having the same issue after swapping to the Zen kernel and trying it out for a few days.
Here is the journalctl post from the last freeze:
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0902] dhcp6 (enp0s31f6): activation: beginning transaction (timeout in 45 seconds)
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0902] dhcp6 (enp0s31f6): state changed no lease
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0906] manager: NetworkManager state is now CONNECTED_SITE
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0907] device (wlp179s0): state change: unavailable -> unmanaged (reason 'unmanaged', sys>
Jun 13 23:32:02 HomeDesktop dbus-daemon[797]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dis>
Jun 13 23:32:02 HomeDesktop dbus-daemon[797]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activati>
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0909] device (wlp179s0): set-hw-addr: reset MAC address to C8:09:A8:9F:4C:D2 (unmanage)
Jun 13 23:32:02 HomeDesktop NetworkManager[854]: <info>  [1686688322.0956] exiting (success)
Jun 13 23:32:02 HomeDesktop systemd[1]: NetworkManager.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Network Manager.
Jun 13 23:32:02 HomeDesktop systemd[1]: NetworkManager.service: Consumed 37.311s CPU time.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopping D-Bus System Message Bus...
Jun 13 23:32:02 HomeDesktop systemd[1]: dbus.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped D-Bus System Message Bus.
Jun 13 23:32:02 HomeDesktop systemd[1]: dbus.service: Consumed 39.986s CPU time.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Basic System.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Path Units.
Jun 13 23:32:02 HomeDesktop systemd[1]: grub-btrfs-snapper.path: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Monitors for new snapshots.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Slice Units.
Jun 13 23:32:02 HomeDesktop systemd[1]: Removed slice Virtual Machine and Container Slice.
Jun 13 23:32:02 HomeDesktop systemd[1]: Removed slice User and Session Slice.
Jun 13 23:32:02 HomeDesktop systemd[1]: user.slice: Consumed 12h 17min 15.903s CPU time.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Socket Units.
Jun 13 23:32:02 HomeDesktop systemd[1]: avahi-daemon.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: cups.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed CUPS Scheduler.
Jun 13 23:32:02 HomeDesktop systemd[1]: dbus.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed D-Bus System Message Bus Socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: libvirtd-admin.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Libvirt admin socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: libvirtd-ro.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Libvirt local read-only socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: libvirtd.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Libvirt local socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: saned.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed saned incoming socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-oomd.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Userspace Out-Of-Memory (OOM) Killer Socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: virtlockd.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Virtual machine lock manager socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: virtlogd.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Virtual machine log manager socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target System Initialization.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Local Encrypted Volumes.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Local Integrity Protected Volumes.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Local Verity Protected Volumes.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopping Set Up Additional Binary Formats...
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Apply Kernel Variables.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Closed Process Core Dump Socket.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Load Kernel Modules.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopping Network Time Synchronization...
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-update-done.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Update is Completed.
Jun 13 23:32:02 HomeDesktop systemd[1]: ldconfig.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Rebuild Journal Catalog.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jun 13 23:32:02 HomeDesktop systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Network Time Synchronization.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-binfmt.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Set Up Additional Binary Formats.
Jun 13 23:32:02 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jun 13 23:32:02 HomeDesktop systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jun 13 23:32:02 HomeDesktop systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped Create Volatile Files and Directories.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopped target Local File Systems.
Jun 13 23:32:02 HomeDesktop systemd[1]: mnt-shared.automount: Deactivated successfully.
Jun 13 23:32:02 HomeDesktop systemd[1]: Unset automount mnt-shared.automount.
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /boot/efi...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /home...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /root...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Jun 13 23:32:02 HomeDesktop umount[1461863]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount point specified.
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /run/credentials/systemd-vconsole-setup.service...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /srv...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /tmp...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /var/cache...
Jun 13 23:32:02 HomeDesktop systemd[1]: Unmounting /var/tmp...
Jun 13 23:32:02 HomeDesktop umount[1461867]: umount: /tmp: target is busy.
Jun 13 23:32:02 HomeDesktop systemd[1]: Stopping Flush Journal to Persistent Storage...
Jun 13 23:32:02 HomeDesktop systemd[1]: boot-efi.mount: Deactivated successfully.
Please let me know if there is anything else i could test out. Thanks!
Issue is still happening after updates, etc
That's kind of funny, since you don't have any quiet kernel parameters and Plymouth is obviously not actually working (since you are seeing the terminal output).
What happens if you remove the splash kernel parameter?
Or, you could try removing Plymouth altogether:
sudo pacman -Rsu plymouth-git
