Hi. I am a Linux novice still but wanted to try out Garuda. I installed the KDE Dragonized edition.
Usually after I install a package, I can do a "which xxx" to make sure the package is accessible.
I think I am confused on a couple of fronts. I am not 100% sure why some of my packages are not accessible and some are not (Example: nvm & fisher).
my echo $PATH output is
/usr/local/sbin /usr/local/bin /usr/bin /usr/bin/site_perl /usr/bin/vendor_perl /usr/bin/core_perl
Am I missing a critical path?
Secondly, I am using makepkg for the first time. I seem to be able to build a package no problem. I built one for Chrome no problem. But I am having trouble after building fisher. It says it installed okay but I can't access it after the fact.
I've been looking over documentation for a number of hours and if someone can point me in the right direction, I would be grateful. I think I am just having a hard time wrapping my head around a couple things that should be simple.
Thanks!
