Parshv - inxi
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=41df06e5-960c-4ccf-9936-a576d2081267 rw [email protected]
resume=UUID=bce75de9-269e-4b91-b0f7-efd3895353d5 loglevel=3
Type: Laptop System: Acer product: Aspire A315-22 v: V1.09
Mobo: SR model: Rose_SR v: V1.09 serial: <superuser required>
UEFI: Phoenix v: 1.09 date: 05/15/2020
ID-1: BAT0 charge: 16.2 Wh (50.3%) condition: 32.2/36.7 Wh (87.6%)
volts: 11.1 min: 11.3 model: LGC AC14B18J type: Li-ion serial: <filter>
status: Discharging cycles: 222
Info: model: AMD A4-9120e RADEON R3 4 COMPUTE CORES 2C+2G bits: 64
type: MCP arch: Excavator family: 0x15 (21) model-id: 0x70 (112)
stepping: 0 microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1287 high: 1391 min/max: 1100/1500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1184 2: 1391
bogomips: 5988
STIBP: disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 00:01.0
chip-ID: 1002:98e4 class-ID: 0300
Device-2: Quanta VGA WebCam type: USB driver: uvcvideo bus-ID: 2-4:2
chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lite-On driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 1.03 TiB used: 29.65 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Acer model: SSD FA100 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1.Z.J.2X
temp: 19.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 29.62 GiB (14.8%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 31.9 MiB (33.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 200 GiB size: 200 GiB (100.00%)
used: 29.62 GiB (14.8%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 7.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 225 Uptime: 5m wakeups: 1 Memory: 7.17 GiB used: 2.1 GiB (29.2%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0
Packages: pacman: 1518 lib: 425 Shell: fish v: 3.3.1 default: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
