sorry to bother you
i make it short
after installation new updates
there is no symbol of pacman
and proceed pacman is not running
can you fix it pls
sorry to bother you
i make it short
can you fix it pls
Try to change icons from the kde setting. This may happens if you change the global theme.
sorry i don't know what the prob was eventually
i only want the the symbol back in tasklist
it called software add/delete
i don't know if pacman was broken
only thing after new updates the symbol was not there anymore
i reinstall pacman
with
pacman -Syu pacman
and then i seach pa..... and there stands software add/delete in menue
i started it and add back to symbol-bar
only thing that doesn't work ist start the command -proceed pacman from menue in searchbar
but i thing it was also before in terminal everything is okay
i don't have change any theme manually
when then it was changed in update process
but for me it worked start the software add/delete programm in seach in menue
and add it back to symbol bar
don't know where excactly was the problem
but thank you anyway
You may confuse pacman with pamac.
Pamac is a gui app to handle packages.
pacman is an old game... oh, just joking. Pacman is a terminal only utility, basic in Archlinux packaging.
i mean pamac sorry
After update pamac to v.10.x at me the Tasksymbol also gone .
i get it back after edit the file pamac-tray.desktop in etc/xdg/autostart
StartupNotify i change from false to true and at notShowin i remove KDE … after reboot the icon was there
StartupNotify=true
NotShowIn=GNOME;
Please post the actual output from running the command, as text. That way people might know what the issue is rather than having to guess.
They may actually have lost the tray icon after the update, I just ran into it yesterday. I ended up removing pamac-all and installing panac-aur and it's Flatpak, snap, and systray components. Then going into Autostart and adding pamac-tray.
sorry but i mean on one hand the icon for pamac that was not there after update
and on the other hand look like the gif it is shown the function is not working but shown
for me worked only starting in menu with seach after pamac and drop down to taskbar
thank you guy for the awesome help
there are many ways i think to fix it
