Package installation Problem
  Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=fda8a0a5-722d-46f7-8ec5-94eda5810359 rw rootflags=subvol=@
    resume=UUID=e4e510cb-8fe0-461a-b564-d6596ced6432 loglevel=3 ibt=off
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 wm: muffin dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 serial: N/A
    BIOS: Award v: F2 date: 11/25/2014
  Info: model: AMD FX-6300 socket: 754 (M2) note: check bits: 64 type: MT MCP
    arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
    model-id: 2 stepping: 0 microcode: 0x6000852
  Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
    desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1500 high: 2000 min/max: 1400/3500 boost: enabled
    base/boost: 3500/3000 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.5 V ext-clock: 200 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
    5: 1400 6: 2000 bogomips: 42184
  Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
    vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
    bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 47.0 C
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    s-diag: 414mm (16.31")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC 1970W serial: <filter>
    built: 2015 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
    size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
    max: 1366x768 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon RX 550 / 550 Series
    (polaris12 LLVM 15.0.7 DRM 3.49 6.2.10-zen1-1-zen) direct-render: Yes
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
    bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0
  API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.68 status: n/a (root, process) with:
    lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: enp0s19f2u4 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
    v: kernel bus-ID: 3-4:3 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
  Report: bt-service: enabled,stopped note: tool can't run
  Local Storage: total: 2.87 TiB used: 1.86 TiB (64.7%)
    model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
    scheme: MBR
    model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3160215AS
    size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: <filter> rev: B scheme: MBR
  ID-1: / raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
    used: 391.01 GiB (42.6%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1
  ID-2: /home raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
    maj-min: 8:1
  ID-3: /var/log raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
    maj-min: 8:1
  ID-4: /var/tmp raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
    maj-min: 8:1
  ID-1: swap-1 type: zram size: 11.67 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 12.83 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1424
  Processes: 276 Uptime: 23m wakeups: 0 Memory: 11.67 GiB
  used: 5.83 GiB (50.0%) Init: systemd v: 253 default: graphical
  pkgs: 1723 libs: 547 tools: octopi,pamac,paru pm: flatpak pkgs: 0
  Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.26
  System install date:     2023-03-24
  Last full system update: 2023-04-08
Haguichi package
whenever i try to install it , it giving me me error
error: haguichi: signature from "Pedro Henrique Lara Campos " is invalid
:: File /var/cache/pacman/pkg/haguichi-1.4.5-1.1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Have you tried a garuda-update before?
Try also deleting that file, to download it again. Just in case...
i did it , i re-download it , update keyring still didn't work.
garuda-update remote keyring
is the magic command to fix keyring issues.
garuda-update remote fix
is the magic command to fix keyring, pacman binary (for example pacman refusing to start, etc), pacman config, mirror, etc issues.
garuda-update remote fullfix
is the command that will do all that remote fix does, except also reinstall all packages.
MAGIC COMMAND DIDN'T WORK
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Download of haguichi (1.4.5-1.1) started
Download of haguichi (1.4.5-1.1) finished
Checking keyring...
Checking integrity...
Error: haguichi: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is invalid
Removing invalid files and retrying...
Checking keyring...
Failed to commit transaction:
invalid or corrupted package (PGP signature):
chaotic -aur package has corruption not aur package.
This is the relevant latest build log.
It looks like there was an error at the end?
Maybe someone can help rebuild?
https://builds.garudalinux.org/repos/chaotic-aur/logs/haguichi.log
No clue if this is still required, but from my experience with Chaotic keyring errors, running the pacman-key steps from the installation guide here always works.
if i am not wrong its for those who wants to create custom packages or offline packages, then it didn't help much .
i just removed the chaotic-aur version and reinstall the aur-git version and its automatically got fixed.
Oh hey, and I thought it was a system issue:
error: freetube: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is invalid
:: File /var/cache/pacman/pkg/freetube-0.18.0-2.1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
I think this guy's key expired, if that is a thing
