Hopefully I am posting in the right category.
Fairly new to Garuda.
Does anyone have a link or a link to a manual that will help me install MS internet Explorer on Garuda?
I need IE for work, have been dual booting as a workaround for now, but I can't stand having to log into windows just to use IE for 2 minutes here and there.
I did get MS Edge installed and works fine, but no luck with IE.
Don' ask me why my employer is so archaic in still using IE as an interface for 1 online tool we use. It really doesn't make any sense.
Ahh, it is simple. First install desirable vm from Setup Assistant. Then, download windows iso for vm. And then boot into it using particular guide for the vm, you just installed.
And I hope, you got the answer. I am marking it solved now.
