Hi
I tried to use yay to update my system because doing it through the assistant kept timing out. However, the update would also fail when I used yay because of an unrecoverable package conflict, and when I try to uninstall on of the packages causing the conflict, my computer says it does not exist.
Do you guys have any ideas on what to do? Thanks!
╭─haquilus@zepharus in ~ as 🧙 took 13ms
╰─λ yay
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
blackarch is up to date
warning: insync-dolphin: local (3.5.2.50118-1) is newer than chaotic-aur (3.4.0.40973-1)
:: Replace lib32-sdl with multilib/lib32-sdl12-compat? [Y/n] Y
:: Replace libinput-gestures-git with chaotic-aur/libinput-gestures? [Y/n] Y
:: Replace qemu with extra/qemu-desktop? [Y/n] Y
resolving dependencies...
:: sweet-theme-full-git and sweet-kde-git are in conflict (sweet-kde). Remove sweet-kde-git? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
-> error installing repo packages
╭─haquilus@zepharus in ~ as 🧙 took 12s
[🔴] × yay -R sweet-theme-full-git
error: target not found: sweet-theme-full-git
-> exit status 1
By the way, here is the output from garuda-inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d01d99ed-791b-4c30-b304-25f263640077 rw rootflags=subvol=@
resume=UUID=acf4428b-a2f4-4c6e-b4e1-6a2cc9893a66 loglevel=3
Type: Laptop System: ASUSTeK product: Zephyrus G GU502DU_GA502DU v: 1.0
Mobo: ASUSTeK model: GU502DU v: 1.0 serial: <filter>
UEFI: American Megatrends v: GU502DU.203 date: 03/27/2019
ID-1: BAT0 charge: 44.0 Wh (100.0%) condition: 44.0/76.0 Wh (58.0%)
status: not charging
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1512 high: 2300 min/max: 1400/2300 boost: enabled
base/boost: 2300/4000 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 2300 7: 1400 8: 1400 bogomips: 36732
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2191
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: amdgpu
Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (raven LLVM 13.0.1 DRM 3.44
5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 5-2:3 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 170.71 GiB (35.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C
temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 256d 10h cycles: 903
read-units: 18,258,912 [9.34 TB] written-units: 18,600,851 [9.52 TB]
ID-1: / raw-size: 461.62 GiB size: 461.62 GiB (100.00%)
used: 170.71 GiB (37.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 461.62 GiB size: 461.62 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 461.62 GiB size: 461.62 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 461.62 GiB size: 461.62 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: partition size: 15.02 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 13.65 GiB used: 263.2 MiB (1.9%)
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): cpu: 4400
Processes: 328 Uptime: 3h 2m wakeups: 14 Memory: 13.65 GiB
used: 5.26 GiB (38.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2430 lib: 506
inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-02-01
Last full system update: 2022-05-15
Is partially upgraded: Yes
