Overclock cpu
this is the output from
dmidecode -t processor<
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
Handle 0x002D, DMI type 4, 48 bytes
Processor Information
Socket Designation: U3E1
Type: Central Processor
Family: Core i7
Manufacturer: Intel(R) Corporation
ID: C1 06 08 00 FF FB EB BF
Signature: Type 0, Family 6, Model 140, Stepping 1
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
Voltage: 0.8 V
External Clock: 100 MHz
Max Speed: 4700 MHz
Current Speed: 2800 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x002A
L2 Cache Handle: 0x002B
L3 Cache Handle: 0x002C
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 4
Core Enabled: 4
Thread Count: 8
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
is it safe to get it to 4700 MHz? How do I do this?
The CPU is rated to that speed for boosting, so possibly.
Did you do any research at all before posting? What have you tried? What didn't work?
https://wiki.archlinux.org/title/Improving_performance#Overclocking
Also note that if you do alter your hardware and break it, it is your fault.
