Hello.
I got problem when I run sudo pacman -Syu:
os-prober-btrfs and os-prober-garuda are in conflict (os-prober). Remove os-prober-garuda?
Am I must remove os-prober-garuda? And If I replace that, what's the side effect of removing it?
Hello.
os-prober-btrfs replaces os-prober-garuda so you should probably say yes to the replacement.
Hey @dalto
I did say yes to this but now my GRUB menu does not show my Windows installation. When I run update-grub
, in the output I got an error like line /usr/share/os-prober/common.sh: line 2: /usr/lib/newns: No such file or directory
and on running os-prober --help
I got the same thing. So, I guess os-prober-btrfs is broken or is there any other problem?
Try,
sudo grub-mkconfig -o /boot/grub/grub.cfg
update the system again this time it will work
i removed the offending patch
Yes, it works now. Thanks
Hi, I have the same problem. My os-prober-btrfs is on version 1.79-2 and it doesn't find my Windows installation anymore.
Windows is overrated but give it a try with
sudo update-grub
Yeah, just running os-prober (for which there appears to be no help or man page) only finds the btrfs volumes, and doesn't show Windows at all.
╭─***@Omen17 in /boot/grub🔒 took 2s
╰─λ sudo os-prober --help
/dev/sdb2:Garuda Linux:Garuda:linux:btrfs:UUID=4e82da31-89de-47a1-a764-d98b8c67f439:subvol=
/dev/sdb2:Garuda Linux:Garuda1:linux:btrfs:UUID=4e82da31-89de-47a1-a764-d98b8c67f439:subvol=@
I just upgraded today as well, and my Windows 10 installation is no longer coming up after upgrading to os-prober-btrfs, either. I've tried the various update-grub suggestions, but they do not work, either. Whatever y'all did removed some very much-used functionality from GRUB, and it's going to force me to use the BIOS hotkey every time I want to reboot into Windows. Please fix this. It's going to become a major knock against this distribution, which I otherwise like very much and champion to others.
No, it isn't.
xx@Omen17 in ~ took 17s
[🔴] × sudo pacman -Syu os-prober-btrfs
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
DEB_Arch_Extra 3.1 KiB 4.10 KiB/s 00:01 [------------------------------------] 100%
warning: os-prober-btrfs-1.79-2 is up to date -- reinstalling
I'm at the newest version, and when I run os-prober, this still happens:
╭─xx@Omen17 in ~ took 8ms
[🔴] × sudo os-prober
/dev/sdb2:Garuda Linux:Garuda:linux:btrfs:UUID=4e82da31-89de-47a1-a764-d98b8c67f439:subvol=@
Whatever y'all changed, it's no longer seeing Windows 10 on the nvme. This is NOT resolved.
What @SGS is saying is that the original issue is resolved. The original question was about doing a replacement. Your issue is about Windows not being detected by os-prober. You should open your own topic instead of using this one which is marked resolved.
