Hello, i saw this in the settings. Will you remove prime or do you plan keep both methods? Optimus manager and prime will be side by side?
Why would this be removed?
It’s the approach which allows best render offload capacity for supported GPUs (i.e. iGPU is used by default, dGPU is used when you run an application with prime-run
I know how to use prime-run
and optimus manager, but i had afraid. Okay there will be both way how to manage GPUs. It's cool
Thank you
