Hello,
I am coming to you following a problem with VPN connections (Via the import of openvpn file in the network manager)
When I create a VPN connection and connect to it, I can no longer reach the internet.
When I look at the routes I see a new default route.
I checked the box "Ignore the routes obtained automatically" but that does not change anything.
When I go through sudo openvpn command it works.
How can I solve the problem without going through the terminal to activate my VPN connection and keep my default route?
I found how to correct this, for information for anyone who would not have checked this box like me, it is necessary to check the box:
"Use only for resources on this connection"
DId you just create a thread and were just like "nvm figured it out."
