OMG… So i did the 15 minute reset but something else came to mind when I read
Did a little digging and found a rule for monitoring logitech wireless device batteries, I remember that I have a dongle for my 3Dconnexion Spacemouse which on some distros (Pop) is recognized in their power monitoring system. So I removed the dongle, powered on (after being unplugged ) and voila, i can successfully boot… I have rebooted a couple of times and it does seem to have remediated the issue. Then after I logged on I plugged the dongle in and the machine instantly went to sleep. I woke it up and repeated the test and yup, machine goes to sleep instantly. Bizarre…
Still would like to know where that pstate setting is coming from…
Here are the outputs for the items above:
grep -i cmdline /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 splash"
GRUB_CMDLINE_LINUX=""
cat /proc/cmdline
intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq root=UUID=9c973da9-123d-4f78-a89a-dc27f5f983fe rw rootflags=subvol=@ rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 splash
systemctl status systemd-logind
â—Ź systemd-logind.service - User Login Management
Loaded: loaded (/usr/lib/systemd/system/systemd-logind.service; static)
Active: active (running) since Fri 2021-02-05 21:46:04 EST; 19min ago
Docs: man:sd-login(3)
man:systemd-logind.service(8)
man:logind.conf(5)
man:org.freedesktop.login1(5)
Main PID: 567 (systemd-logind)
Status: "Processing requests..."
Tasks: 1 (limit: 19064)
Memory: 3.4M
CPU: 0
CGroup: /system.slice/systemd-logind.service
└─567 /usr/lib/systemd/systemd-logind
Feb 05 21:46:05 wkd-main systemd-logind[567]: Watching system buttons on /dev/input/event27 (Razer Razer Viper Mini)
Feb 05 21:46:05 wkd-main systemd-logind[567]: Watching system buttons on /dev/input/event19 (ZSA Technology Labs Inc ErgoDox EZ Glo>
Feb 05 21:46:05 wkd-main systemd-logind[567]: Watching system buttons on /dev/input/event23 (Razer Razer Viper Mini Keyboard)
Feb 05 21:46:05 wkd-main systemd-logind[567]: Watching system buttons on /dev/input/event17 (ZSA Technology Labs Inc ErgoDox EZ Glo>
Feb 05 21:46:07 wkd-main systemd-logind[567]: New session c1 of user sddm.
Feb 05 21:46:15 wkd-main systemd-logind[567]: New session 2 of user wayne.
Feb 05 21:46:15 wkd-main systemd-logind[567]: Session c1 logged out. Waiting for processes to exit.
Feb 05 21:46:15 wkd-main systemd-logind[567]: Removed session c1.
Feb 05 21:48:10 wkd-main systemd-logind[567]: Operation 'sleep' finished.
Feb 05 21:48:49 wkd-main systemd-logind[567]: Operation 'sleep' finished.
systemctl status thermald
â—Ź thermald.service - Thermal Daemon Service
Loaded: loaded (/usr/lib/systemd/system/thermald.service; enabled; vendor preset: disabled)
Active: inactive (dead) since Fri 2021-02-05 21:46:04 EST; 22min ago
Main PID: 570 (code=exited, status=0/SUCCESS)
CPU: 0
Feb 05 21:46:04 wkd-main systemd[1]: Starting Thermal Daemon Service...
Feb 05 21:46:04 wkd-main thermald[570]: NO RAPL sysfs present
Feb 05 21:46:04 wkd-main thermald[570]: Unsupported cpu model or platform
Feb 05 21:46:04 wkd-main systemd[1]: Started Thermal Daemon Service.
Feb 05 21:46:04 wkd-main systemd[1]: thermald.service: Succeeded.
Now here’s an interesting bit, I pulled this from the log:
upowerd[2386]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-3
This usb device is identified as the Spacemouse and it appears to be kicking off the upowerd service.
I am heading in the right direction? And could this be one of the UDEV rules kicking the suspend?
