Hello All
I tried upgrading garuda linux via pacman -Syu and octopi notifier but I keep getting the error:
checking keys in keyring
checking package integrity
error: octopi: signature from "Nico Jensch (Chaotic-AUR) " is invalid
:: File /var/cache/pacman/pkg/octopi-0.12.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
[?25h
Command finished with errors!
inxi -Faz
╭─nik@TUF in ~ via v16.11.1
╰─λ inxi -Faz
System: Kernel: 5.14.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=85971d7e-f881-4611-9efe-f3c045277afd
systemd.unified_cgroup_hierarchy=1 resume=UUID=7477f681-f16a-46a9-aed0-7e8e81a9f785 loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IU_FA506IU v: 1.0
Mobo: ASUSTeK model: FA506IU v: 1.0 serial: <filter> UEFI: American Megatrends v: FA506IU.316
date: 03/12/2021
Battery: ID-1: BAT1 charge: 40.6 Wh (97.1%) condition: 41.8/48.1 Wh (86.9%) volts: 12.6 min: 11.7
model: ASUS A32-K55 type: Li-ion serial: N/A status: Unknown
CPU: Info: 8-Core model: AMD Ryzen 9 4900H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105400
Speed: 3037 MHz min/max: 1400/3300 MHz boost: enabled Core speeds (MHz): 1: 3037 2: 2057
3: 2550 4: 1397 5: 1453 6: 4117 7: 1616 8: 1724 9: 3965 10: 4439 11: 1626 12: 1630 13: 1618
14: 1955 15: 2471 16: 1396
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 06:00.0
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,nvidia
Screen-1: 0 s-res: 4920x2560 s-dpi: 96 s-size: 1298x675mm (51.1x26.6") s-diag: 1463mm (57.6")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Monitor-2: HDMI-A-0 res: 1080x2560 hz: 60
Monitor-3: DP-1-0.1 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-4: DP-1-0.2 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.15-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 06:00.1
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Realtek USB Audio type: USB driver: snd-usb-audio bus-ID: 3-1.5:4 chip-ID: 0bda:4014
Device-6: Kingston HyperX Cloud Stinger Core + 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.6:5 chip-ID: 0951:1709 class-ID: 0300
Sound Server-1: ALSA v: k5.14.15-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 4-1.2:3
IF: enp6s0f3u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 5-1:2
chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Drives: Local Storage: total: 2.05 TiB used: 381.57 GiB (18.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
rev: P3CR013 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
rev: P3CR013 temp: 38.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS250G1B0A-00H9H0 size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
Partition: ID-1: / raw-size: 862.8 GiB size: 862.8 GiB (100.00%) used: 80.5 GiB (9.3%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 862.8 GiB size: 862.8 GiB (100.00%) used: 80.5 GiB (9.3%) fs: btrfs
ID-4: /var/log raw-size: 862.8 GiB size: 862.8 GiB (100.00%) used: 80.5 GiB (9.3%) fs: btrfs
ID-5: /var/tmp raw-size: 862.8 GiB size: 862.8 GiB (100.00%) used: 80.5 GiB (9.3%) fs: btrfs
ID-1: swap-1 type: partition size: 68.46 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:5
ID-2: swap-2 type: zram size: 62.23 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 68.9 C mobo: 68.0 C gpu: amdgpu temp: 56.0 C
Fan Speeds (RPM): cpu: 2700
Info: Processes: 409 Uptime: 7m wakeups: 1 Memory: 62.23 GiB used: 5.41 GiB (8.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1806 lib: 535
I tried
sudo pacman -Syu --debug
debug: signature is valid
debug: signature is fully trusted
debug: found cached pkg: /var/cache/pacman/pkg/xorg-xwayland-21.1.3-1-x86_64.pkg.tar.zst
debug: sig data: iQEyBAABCAAdFiEErcih/MFeAdRTEEGelGV6sg8qCSsFAmGJcF4ACgkQlGV6sg8qCSsRXAf2OU4kkuUmT1xwuFqOLrP5H
eebLZjuWf+E8JMiLwtytIAEauWVfhphhGCNIZiWXgWyOGRwQXeQLS2mb8jDgy/yI+UxTptb4fS56kHsVnCPqHZi0juH81N51meHKhBXp0a17mL
uhO109zDex3Ja+PwQRAp/ZBnH3OicmnrwI/TG19DX3LIDzqijcXmQBL6eWgZZIUPA7cDvEEQgyiMqfd4weWkQIISgEl0a4iGg/5QMVawtPGz01
2aBiTuq/Df6Lz3am9xiKPgMzra6Lp6sQriQV+VJ5KtO4gl9LDyWcBN36vXTsPSwFsj6h3vsGfjt7FmSqsGc1s7lwAnsbhWaq/0n
debug: checking signature for /var/cache/pacman/pkg/xorg-xwayland-21.1.3-1-x86_64.pkg.tar.zst
debug: 1 signatures returned
debug: fingerprint: ADC8A1FCC15E01D45310419E94657AB20F2A092B
debug: summary: valid
debug: summary: green
debug: status: Success
debug: timestamp: 1636397150
debug: exp_timestamp: 0
debug: validity: full; reason: Success
debug: key: ADC8A1FCC15E01D45310419E94657AB20F2A092B, Andreas Radke <[email protected]>, owner_trust unkno
wn, disabled 0
error: octopi: signature from "Nico Jensch (Chaotic-AUR) <[email protected]>" is invalid
GP signature)).
Do you want to delete it? [Y/n]
if I hit y or n I keep seeing the same message that it failed as the file is corrupt/invalid or failed to commit a transaction
debug: returning error 35 from check_validity (../lib/libalpm/sync.c: 1050) : invalid or corrupted package
debug: unregistering database 'local'
debug: freeing package cache for repository 'local'
debug: unregistering database 'core'
debug: freeing package cache for repository 'core'
debug: unregistering database 'extra'
debug: freeing package cache for repository 'extra'
debug: unregistering database 'community'
debug: freeing package cache for repository 'community'
debug: unregistering database 'multilib'
debug: freeing package cache for repository 'multilib'
debug: unregistering database 'chaotic-aur'
debug: freeing package cache for repository 'chaotic-aur'
I found the other post with a similar error for a different package. and have tried sudo pacman -Sy chaotic-keyring, but the problem for this specific package does not seem to go away
Any suggestions/recommendations will be much appreciated. Thanks!
