My Google Foo has not helped me figure this out.
When adding a source to OBS Studio the menus glitch out when resizing menu items.
I would post a screen shot but it says because I am new I am not allowed.
I have tested this on different hardware and different Garuda DE's seems to only be a problem with Garuda flavors. Manjaro and EndeavourOS do not seem to suffer from this GUI glitch.
I have tried changing the OBS Studio Theme and that doesn't seem to help either.
Thank you in advanced for any help or ideas!
Kernel: 5.17.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=638028fd-ad4b-45ea-bb4a-dcdd8da652a1 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.33 wm: muffin vt: 7
dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X570M Pro4 serial: <superuser required>
UEFI: American Megatrends v: P3.70 date: 02/23/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3589 high: 3594 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3591 2: 3592
3: 3587 4: 3589 5: 3584 6: 3591 7: 3593 8: 3581 9: 3591 10: 3588 11: 3594
12: 3593 bogomips: 86242
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GP107GL [Quadro P400] driver: nvidia v: 515.43.04
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:1cb3 class-ID: 0300
Device-2: USB3.0 HD Audio Capture Video type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: eba4:7588
Device-3: A4Tech USB Live camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-3:4 chip-ID: 09da:2690 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 82
Monitor-2: DP-4 pos: right res: 1920x1080 hz: 60 dpi: 82
Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: USB3.0 HD Audio Capture Video type: USB
Device-4: A4Tech USB Live camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.7-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Local Storage: total: 1.36 TiB used: 590.84 GiB (42.3%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
rev: 613000WD temp: 47.9 C scheme: GPT
model: WDS500G1X0E-00AFY0 size: 465.76 GiB block-size: physical: 512 B
rev: 613000WD temp: 46.9 C scheme: GPT
used: 182.14 GiB (39.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.54 GiB used: 149 MiB (0.9%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Processes: 368 Uptime: 5d 5h 21m wakeups: 125 Memory: 15.54 GiB
used: 3.67 GiB (23.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1495 lib: 353 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-04-16
Last full system update: 2022-05-20 ↻
