OBS, BTRFS not opening after changing permissions on sudo
hi i changed sudo permissions while trying to fix something and got this error
sudo must be owned by uid 0 and have the setuid bit set
I booted into recovery mode and ran this
# remount disks in read write mode
mount -o remount,rw /
mount --all
# return ownership
chown root:root /usr/bin/sudo
# fix permissions
chmod 4755 /usr/bin/sudo
reboot
this brought back my sudo access via terminal but now a lot of programs arent opening including OBS and BTRFS-assistant. I started running into trouble after accidentally upgrading my OBS to 29 and trying to downgrade back to OBS 27. would appreciate any help restoring my OBS to 27 and also getting my apps to open.
my snapshots unbeknownst to me were not saving to my other hd so I can't restore a snapshot.
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=bb27ee55-86c8-4c74-93f1-06004daa8c34 rw [email protected]
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 info: latte-dock
Mobo: ASUSTeK model: PRIME Z590-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 0402 date: 01/08/2021
Device-1: hid-04:4b:ed:eb:cc:93-battery model: Claudia's Trackpad
serial: N/A charge: N/A status: discharging
Device-2: hid-e0:eb:40:cd:73:bd-battery model: Claudia Cho’s Keyboard
Info: model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x57
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2842 high: 3500 min/max: 800/5100:5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 801 3: 3500
4: 3500 5: 3500 6: 3500 7: 3500 8: 818 9: 3500 10: 1053 11: 3500 12: 3500
13: 3500 14: 3500 15: 3500 16: 3500 bogomips: 112128
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,DVI-D-1 bus-ID: 0000:01:00.0 chip-ID: 1002:67df
Device-2: Realtek NexiGo N660P FHD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7:7 chip-ID: 0bda:0567
Device-3: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-7:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
s-diag: 1055mm (41.54")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: right model: Samsung C27F390
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Acer EB321HQ A serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.2.11-zen1-1-zen) direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 1-13:10 chip-ID: b58e:9e84
alternate: snd_sof_pci_intel_tgl class-ID: 0300 bus-ID: 0000:00:1f.3
serial: <filter> chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
Device-4: Realtek NexiGo N660P FHD Webcam type: USB
Device-5: Logitech BRIO Ultra HD Webcam type: USB
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 0000:03:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-1: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 1-11:8 chip-ID: 19ff:0239 class-ID: fe01
Hardware-1: Intel Device driver: intel_nvme_remap v: N/A port: 4020
bus-ID: 0000:00:17.0 chip-ID: 8086:43d6 rev: N/A class-ID: 0104
Local Storage: total: 2.76 TiB used: 504.69 GiB (17.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 3B2QGXA7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Walgreen model: Infinitive
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 361.43 GiB (19.4%)
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 361.43 GiB (19.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 695
Processes: 396 Uptime: 9m wakeups: 3 Memory: 31.2 GiB used: 5.29 GiB (17.0%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1889 libs: 524
tools: octopi,pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.1
System install date:     2022-08-02
Last full system update: 2023-04-16 ↻
Can you describe more specifically what you changed? If you can pull up the exact commands that would be informative I think.
I used the GUI's right click Root Actions menu to change permissions of usr/bin/sudo
I didn't use any commands until I tried to fix the error
... Why did you do that in the first place?
What if you run the troublesome programs, like OBS via the terminal?
What about just straight up restoring a snapshot?
I was trying to downgrade OBS. I think I hugely messed up some file permissions.
when I try to access snapshots via gui it doesnt work so I tried
sudo btrfs-assistant
getting same error
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
I should also note I tried to change file permissions recursively
EDIT
I fixed sudo permissions by logging into root and running
garuda-update
pacman -S sudo
OBS 29 opens but my issue is trying to downgrade to obs 27. I downloaded the obs 27 package from arch linux archive and installed the package by running
sudo pacman -U /home/cc/Downloads/obs-studio-27.2.4-2-x86_64.pkg.tar.zst
the downgrade performs sucessfully but when I try to open OBS 27 from terminal I get this error
obs: error while loading shared libraries: libavcodec.so.59: cannot open shared object file: No such file or d
irectory
Literally use downgrade for that. The issue with downgrading packages is, that there is usually a pretty large dependency network between packages. If you downgrade one, chances are that you need to downgrade like all the related packages, because all of them want older versions of libraries that the downgraded package wants.
No good way around that.
I ended up using
paru
to search for and download the missing libraries.
OBS 27 successfully opens!
my plugins are missing tho.
