Nwgbar Suspend not working
Hello.
I'm trying to get my computer to suspend through the nwgbar but I'm getting an error when I try to run the command. The error basically says it doesn't know how to interpret the suspend;swaylock combination command.
╰─λ nwgbar
INFO: wm: sway
INFO: 5 bar entries loaded
INFO: Using css file '"/home/giesiger/.config/nwg-launchers/nwgbar/style.css"'
INFO: Time: 90ms
Unknown command verb suspend;swaylock.
  Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=5ea32362-776b-4a64-a2e7-1e1492b1137b rw [email protected]
    resume=UUID=99213909-149f-4663-8cb0-b7431f100328 loglevel=3
  Desktop: sway 1.7 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: XPS 13 9350 v: N/A
  Mobo: Dell model: 0PWNCR v: A01 serial: <superuser required> UEFI: Dell
    v: 1.11.1 date: 08/01/2019
  ID-1: BAT0 charge: 32.3 Wh (100.0%) condition: 32.3/56.0 Wh (57.7%)
    volts: 8.6 min: 7.6 model: LGC-LGC7.3 DELL 5K9CP5A type: Li-ion
    serial: <filter> status: Full
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3036 high: 3059 min/max: 400/3100 scaling:
    driver: intel_pstate governor: performance cores: 1: 3059 2: 3032 3: 3022
    4: 3031 bogomips: 20799
  Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
    bus-ID: 1-5:4 chip-ID: 0c45:670c class-ID: 0e02
  Display: wayland server: N/A compositor: sway v: 1.7 driver: loaded: i915
    note: n/a (using device driver) display-ID: 1
    resolution: <missing: xdpyinfo>
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.44 running: yes
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 3a:00.0
    chip-ID: 8086:095a class-ID: 0280
  IF: wlp58s0 state: up mac: <filter>
    bus-ID: 1-3:3 chip-ID: 8087:0a2a class-ID: e001
    address: <filter>
    v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 465.76 GiB used: 18.54 GiB (4.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
    used: 18.54 GiB (4.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
  ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
  ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.63 GiB used: 2.1 MiB (0.0%) priority: 100
  System Temperatures: cpu: 59.0 C pch: 50.0 C mobo: 43.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 227 Uptime: 21h 34m wakeups: 3 Memory: 7.63 GiB
  used: 2.38 GiB (31.2%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1282 lib: 316 Shell: Zsh v: 5.8
  running-in: alacritty inxi: 3.3.12
Garuda (2.5.3-1):
  System install date:     2021-12-08
  Last full system update: 2022-02-01
I have tried to change the command and it doesn't seem to help. Any suggestions for me to try would be welcome.
Thanks
I noticed too. I removed the ;swaylock part and it works, screen locking included.
Looks like that command is unnecessary, but I haven't yet looked into what actually happens.
The config file is ~/.config/nwg-launchers/nwgbar/bar.json.
    "name": "Suspend",
    "exec": "systemctl suspend",
