Hello,
I have a bit of unusual setup and need some help stabilizing the system. I’m running garuda for quite some time on mid 2011 model iMac 27. Recently the video card died (AMD) and i replaced it with what i was able to find - compatible nvidia Quadro K1100M
now i have the following problems:
Nvidia-dkms driver doesn’t seem to load properly, very sluggish performance (mouse is jumpy), windows animation doesn’t work (i.e. compositing - wobly windows), and it cannot detect second monitor at all.
I used the “hardware configuration wizard” to install the proprietary driver. I think it might be just reverting to the built-in graphics card instead of the actual one.
I would gladly stay on the open source driver because it seems to work better than the proprietary one. At least it loads;) Second monitor works, compositing works, performance is much better, BUT on the main Imac screen there are horizontal streaks that randomly blinking on the right side of the screen. Because nvidia driver doesn’t actually seem to load, i cannot say if these streaks are becasue of a faulty card or a driver problem - nothing to compare it with.
I also noticed the following: the second monitor stops being detected after i install nvidia driver, but just uninstalling nvidia and restarting the system doesn’t seem to solve the problem. So in order to get the open source driver to work i need to manualy uninstall lib32-nvidia-utils and nvidia-utils. Then after restart open source driver kicks in.
any suggestions?
Thank you!
garuda-inxi:
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1bf283ae-baf4-4ada-b572-c757bb8df75e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Apple product: iMac12,2 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-942B59F58194171B
Mobo: Apple model: Mac-942B59F58194171B v: iMac12,2
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 87.0.0.0.0 date: 06/14/2019
Device-1: hidpp_battery_0 model: Logitech Performance MX serial: <filter>
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
Speed (MHz): avg: 2170 min/max: 1600/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2170 2: 2170 3: 2170 4: 2170 5: 2170 6: 2170
7: 2170 8: 2170 bogomips: 54274
vendor: Apple driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: none empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Dell driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2024-09-xx)
arch: Kepler-2 code: GKxxx process: TSMC 28nm built: 2012-2018 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1,eDP-1 empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:0ff6
class-ID: 0300 temp: 55.0 C
Device-3: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 05ac:850b
Device-4: Microdia Angetube Live Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:5
chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
alternate: fbdev,intel,nv,vesa dri: nouveau,crocus gpu: i915,nouveau
d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
device: 0 drv: crocus device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: crocus surfaceless: drv: crocus wayland: drv: nouveau x11:
drv: nouveau
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 24.3.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVE7 device-ID: 10de:0ff6 memory: 1.91 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM
18.1.8 256 bits) driver: mesa llvmpipe v: 24.3.1-arch1.2 (LLVM 18.1.8)
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-2: NVIDIA GK107 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Microdia Angetube Live Camera driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api tools: N/A
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
Device-1: Apple Built-in Bluetooth 2.0+EDR HCI driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1.1:7
chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1
lmp-v: 4 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 1.85 TiB used: 67.32 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 2TB
ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: USB 3.0 FD size: 29.76 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 118.73 GiB size: 118.73 GiB (100.00%)
used: 67.32 GiB (56.7%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 668 MiB size: 666.7 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 118.73 GiB size: 118.73 GiB (100.00%)
ID-4: /var/log raw-size: 118.73 GiB size: 118.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.73 GiB size: 118.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 19.51 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 21.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nouveau temp: 55.0 C
Fan Speeds (rpm): cpu: 936
Memory: total: 20 GiB available: 19.51 GiB used: 5.16 GiB (26.5%)
Processes: 311 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 7.79 GiB services: org_kde_powerdevil,
power-profiles-daemon, thermald, upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 1528 libs: 404 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date: 2024-06-21
Last full system update: 2024-12-07
Is partially upgraded: Yes
