nVidia drivers issue
https://builds.garudalinux.org/iso/garuda/dr460nized-gaming/210104/garuda-dr460nized-gaming-linux-tkg-bmq-210104.iso.torrent
Please let us know if it fixes the issue. :slight_smile:
Just thought I'd mention for your (and others) benefit that posting pictures rather than textual outputs on technical help forums is not the preferred method.
Please use three of these symbols ~ before and after any terminal outputs that you post. This ensures that the output is formatted correctly in a proper code block on the forum.
Example:
your terminal output here
Thank you, and welcome (hopefully) to Garuda.
Any direct links? Torrent isn't starting showing 0 seeds.
@dr460nf1r3
New ISOs are even more broken than previous ones. Empty mirror list, timouts all over the place.. And Gaming one refuses to boot complaining about x64 EFI.. I have x570 Mobo with Ryzen 5, 3600X..
[2021-01-05 12:19:50] WARNING: failed to rate http(s) download (https://ftp.halifax.rwth-aachen.de/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When:       2021-01-05 10:20:00 UTC
# From:       https://www.archlinux.org/mirrors/status/json/
# Retrieved:  2021-01-05 10:19:35 UTC
# Last Check: 2021-01-05 10:08:14 UTC
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
Server = https://phinau.de/arch/$repo/os/$arch
Server = https://mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to update chaotic-aur (unable to lock database)
error: failed to synchronize all databases
Remove .torrent and thats direct link
Please don't necro ancient posts.
