After switching from zen to arch kernel, NVIDIA driver is unloaded and not working. I reinstalled the driver also but it didn't solve the problem. Please help me regarding this!
prime-run nvidia-settings output :
ERROR: NVIDIA driver is not loaded
(nvidia-settings:9485): GLib-GObject-CRITICAL **: 21:57:14.328: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:9485): CRITICAL **: 21:57:14.329: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and
will not be listed in the help text. Please see the README for possible values and descriptions.
garuda-inxi output :
Kernel: 5.16.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=48bcd8f8-8b3f-4880-b42a-006b8a79a3d7 rw [email protected]
resume=UUID=7a1e7bea-7a5f-4dbe-b369-1f62294f03e1 loglevel=3
Desktop: GNOME 41.4 tk: GTK 3.24.33 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
Mobo: HP model: 88DE v: 96.31 serial: <filter> UEFI: AMI v: F.15
date: 08/18/2021
ID-1: BAT0 charge: 50.3 Wh (99.6%) condition: 50.5/50.5 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: N/A
Info: model: AMD Ryzen 5 5600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1375 high: 3300 min/max: 1200/4280 boost: enabled
base/boost: 3300/4250 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 3300 4: 1200
5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200
bogomips: 79075
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: N/A alternate: nouveau pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:0035 class-ID: fe01
Display: server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.14-arch1-1 LLVM 13.0.1)
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.14-arch1-1 running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_pci v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
bus-ID: 1-4:2 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 42.5 GiB (8.9%)
model: MTFDHBA512TDV-1AZ1AABHA size: 476.94 GiB block-size: physical: 512 B
rev: HPS0032 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
used: 42.5 GiB (28.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:8
ID-2: /boot/efi raw-size: 615 MiB size: 613.8 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /home raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 7.18 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 340 Uptime: 48m wakeups: 1 Memory: 7.18 GiB
used: 1.72 GiB (23.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1225 lib: 321 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-13
Last full system update: 2022-03-16
Windows dual boot: Yes
