Hello, i’ve just installed Garuda on my laptop by selecting proprietary driver on install but when i start, only nouveau was installed so i manualy installed DKMS, it’s shown like installed but on hardware configuration i don’t have them displayed on hardware configuration and i have only the “auto install open source driver” option not the proprietary one.
root=UUID=0812c052-4c7c-431f-84ab-ecca589b6143 rw rootflags=subvol=@
ipv6.disable=1 ipv6.disable=1 quiet loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA507NV_FA507NV
Mobo: ASUSTeK model: FA507NV v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FA507NV.312 date: 08/11/2023
ID-1: BAT1 charge: 85.6 Wh (100.0%) condition: 85.6/90.2 Wh (94.9%)
volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 525 high: 1411 min/max: 400/4829 scaling:
4: 1411 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 1397 15: 400 16: 400 bogomips: 102218
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: 35:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 53.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 2b7e:b685
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics B156HAN15.H built: 2022
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.6.1-zen1-1-zen) device-ID: 1002:1681 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia v: 545.29.02
device-ID: 10de:28e0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.1
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 35:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3563
Local Storage: total: 1.38 TiB used: 138.07 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
serial: <filter> scheme: MBR
used: 13.72 GiB (2.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.87 GiB used: 515 MiB (3.4%) priority: 100
System Temperatures: cpu: 61.5 C mobo: 36.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): cpu: 0
Processes: 349 Uptime: 2h 56m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.87 GiB used: 2.77 GiB (18.6%) Init: systemd v: 254
pm: pacman pkgs: 1290 libs: 388 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-19
Last full system update: 2023-11-20 ↻
