NVidia-dkms driver problem
Hi,
I state that this is not the first time this happens but generally by reinstalling the system everything would be fine.
I've been having problems with Nvidia drivers for about a week now.
It all started a week ago when trying to update the system, and Pacman crashed the system while installing the NVidia dkms module. Since I didn't have time to investigate, I restored a snapshot.
Yesterday I decided to wipe, and I could not complete the installation using NVidia's closed source drivers.
I then completed the installation without the NVidia drivers and then installed them later, but the same thing happened as soon as I tried again. The system freezes, and so I am forced to force it to shut down.
I have already checked that the bios is up to date, and it is.
sudo garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=366fbff6-1a66-45bd-b0bd-baf5a6a52039 rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2403 date: 10/27/2021
ID-1: hidpp_battery_0 charge: 84% condition: N/A volts: 4.0 min: N/A
Info: model: Intel Core i9-10900K socket: LGA1200 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xF0
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1963 high: 4864 min/max: 800/5300 base/boost: 3700/8300
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 3619 4: 2894 5: 2130 6: 1356
7: 871 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
16: 2222 17: 4482 18: 4447 19: 4864 20: 4389 bogomips: 147994
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-05) arch: Pascal
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
ports: active: DP-1,DP-2,DP-3 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:7 chip-ID: 046d:082d
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 7280x1440 s-dpi: 96 s-size: 1926x381mm (75.83x15.00")
s-diag: 1963mm (77.3")
Monitor-1: DP-1 pos: primary,top-center model: Mi Monitor built: 2019
res: 3440x1440 hz: 50 dpi: 110 gamma: 1.2 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-2: DP-2 pos: primary,top-left model: AOC 2460G5 serial: <filter>
built: 2017 res: 1920x1080 dpi: 92 gamma: 1.2
Monitor-3: DP-3 pos: bottom-r model: LG (GoldStar) 24GL600F
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
OpenGL: renderer: NV134 v: 4.3 Mesa 22.0.4 direct render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: RODE Microphones NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:07b1
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
bus-ID: 1-14:9 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.61 TiB used: 11.17 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT343.4
temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 30d 1h cycles: 408
read-units: 2,351,965 [1.20 TB] written-units: 6,909,996 [3.53 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 310d 6h cycles: 3153
written: 32.85 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
SMART: yes state: enabled health: PASSED on: 1y 357d 16h cycles: 3428
written: 40.9 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
rev: 1B6Q temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 147d 1h cycles: 3017
written: 40.93 TiB
used: 11.17 GiB (1.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nouveau temp: 37.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 461 Uptime: 5m wakeups: 2 Memory: 31.16 GiB
used: 3.34 GiB (10.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1439 lib: 323 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-05-20
Last full system update: 2022-05-21
Windows dual boot:       Yes
Just check fast boot and secure boot is disabled before the reinstall in your bios as windows has a habit on turning them back on
Just checked, fast boot and secure boot are disabled.
Also, I installed Windows before reinstalling but after the first time I had the problem so I don't think it's related.
Try switching to a different kernel–LTS is a good place to start.
Pull the system up to date:
garuda-update
Install LTS kernel:
sudo pacman -S linux-lts linus-lts-headers
Select “advanced options” on the grub menu to boot to your new kernel.
Have you disconnected your extraneous monitors?
Running 3 monitors isn't exactly a standard setup. I would highly suggest installing with only 1 main monitor to start with.
Edit:
Just read your post history. You've had more than 1 help request relating to your multi monitor setup. Have you tested disabling the kwin compositor?
Multi-monitor setups are fraught with issues as there are many bugs with this type of setup.
I forgot to write that I have already tried with the following kernels: linux, linux-lts, linux-zen, linux-mainline, linux-xanmod-edge
Perhaps you didn't notice my last minute edit just before your last post.
Have you tried setting up your computer with only a single monitor?
Just tried, no difference
The same happens also if I try to install nvidia-dkms from the tty so the compositor isn’t the problem.
Perhaps try searching for some kernel parameters relevant to your motherboard and nvidia.
Test using nomodeset to start with.
Other kernel parameters you might want to test are:
pcie_aspm=off
pci=noacpi
Another thing you could try is installing the older version of the nvidia driver. That is assuming there was an nvidia driver update during the timeframe when your system broke.
https://wiki.archlinux.org/title/downgrading_packages
Okay, those two parameters helped. Now the whole system doesn’t crash anymore.
But it still keeps getting stuck there.
> Using config 'video-nvidia-dkms' for device: 0000:01:00.0 (0300:10de:1b81) Display controller nVidia Corpora
tion GP104 [GeForce GTX 1070]
> Installing video-nvidia-dkms...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
blackarch downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: nvidia-utils will be installed before its egl-wayland dependency
Packages (37) blas-3.10.1-1  cblas-3.10.1-1  egl-wayland-2:1.1.9+r3+g582b2d3-1  eglexternalplatform-1.1-2  gob
ject-introspection-1.72.0-1  gwe-0.15.5-1  lapack-3.10.1-1  lib32-nvidia-utils-515.43.04-1  lib32-opencl-nvidi
a-515.43.04-1  libdazzle-3.44.0-1  libxnvctrl-515.43.04-1  nvidia-dkms-515.43.04-1  nvidia-settings-515.43.04-
1  nvidia-utils-515.43.04-1  opencl-nvidia-515.43.04-1  python-beaker-1.11.0-8  python-cycler-0.11.0-1  python
-dateutil-2.8.2-4  python-fonttools-4.33.3-1  python-importlib-metadata-4.8.1-3  python-injector-0.19.0-1  pyt
hon-kiwisolver-1.3.2-3  python-mako-1.1.6-3  python-markdown-3.3.7-1  python-markupsafe-2.1.1-1  python-matplo
tlib-3.5.2-1  python-numpy-1.22.3-1  python-peewee-3.14.10-1  python-py3nvml-0.2.7-1  python-pyxdg-0.27-4  pyt
hon-rx-3.2.0-3  python-six-1.16.0-5  python-typing_extensions-4.2.0-1  python-xlib-0.31-3  python-zipp-3.8.0-1
qhull-2020.2-4  garuda-nvidia-config-1:r62.889aefa-6
Total Download Size:   313,58 MiB
Total Installed Size:  875,17 MiB
:: Retrieving packages...
nvidia-utils-515.43.04-1-x86_64 downloading...
nvidia-dkms-515.43.04-1-x86_64 downloading...
lib32-nvidia-utils-515.43.04-1-x86_64 downloading...
lib32-opencl-nvidia-515.43.04-1-x86_64 downloading...
python-numpy-1.22.3-1-x86_64 downloading...
python-matplotlib-3.5.2-1-x86_64 downloading...
lapack-3.10.1-1-x86_64 downloading...
python-fonttools-4.33.3-1-x86_64 downloading...
gobject-introspection-1.72.0-1-x86_64 downloading...
qhull-2020.2-4-x86_64 downloading...
nvidia-settings-515.43.04-1-x86_64 downloading...
libdazzle-3.44.0-1-x86_64 downloading...
python-peewee-3.14.10-1-x86_64 downloading...
python-dateutil-2.8.2-4-any downloading...
python-xlib-0.31-3-any downloading...
python-rx-3.2.0-3-any downloading...
gwe-0.15.5-1-any downloading...
python-markdown-3.3.7-1-any downloading...
python-mako-1.1.6-3-any downloading...
blas-3.10.1-1-x86_64 downloading...
python-beaker-1.11.0-8-any downloading...
python-py3nvml-0.2.7-1-any downloading...
python-pyxdg-0.27-4-any downloading...
libxnvctrl-515.43.04-1-x86_64 downloading...
python-kiwisolver-1.3.2-3-x86_64 downloading...
python-injector-0.19.0-1-any downloading...
python-typing_extensions-4.2.0-1-any downloading...
cblas-3.10.1-1-x86_64 downloading...
python-importlib-metadata-4.8.1-3-any downloading...
egl-wayland-2:1.1.9+r3+g582b2d3-1-x86_64 downloading...
python-six-1.16.0-5-any downloading...
python-markupsafe-2.1.1-1-x86_64 downloading...
python-cycler-0.11.0-1-any downloading...
python-zipp-3.8.0-1-any downloading...
eglexternalplatform-1.1-2-any downloading...
garuda-nvidia-config-1:r62.889aefa-6-any downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
==> root: 40
installing nvidia-utils...
If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-utils
nvidia-settings: configuration tool [pending]
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support [pending]
installing eglexternalplatform...
installing egl-wayland...
installing python-markupsafe...
installing python-beaker...
installing python-mako...
installing python-zipp...
installing python-importlib-metadata...
installing python-markdown...
installing gobject-introspection...
installing libdazzle...
installing python-typing_extensions...
installing python-injector...
installing python-six...
installing python-cycler...
installing python-dateutil...
installing python-fonttools...
Optional dependencies for python-fonttools
python-brotli: to compress/decompress WOFF 2.0 web fonts
python-fs: to read/write UFO source files
python-lxml: faster backend for XML files reading/writing
python-lz4: for graphite type tables in ttLib/tables
python-matplotlib: for visualizing DesignSpaceDocument and resulting VariationModel [pending]
python-pyqt5: for drawing glyphs with Qt’s QPainterPath [installed]
python-reportlab: to drawing glyphs as PNG images [installed]
python-scipy: for finding wrong contour/component order between different masters
python-sympy: for symbolic font statistics analysis
python-uharfbuzz: to use the Harfbuzz Repacker for packing GSUB/GPOS tables
python-unicodedata2: for displaying the Unicode character names when dumping the cmap table with ttx
python-zopfli: faster backend fom WOFF 1.0 web fonts compression
installing python-kiwisolver...
installing blas...
installing cblas...
installing lapack...
installing python-numpy...
Optional dependencies for python-numpy
openblas: faster linear algebra
installing qhull...
installing python-matplotlib...
Optional dependencies for python-matplotlib
tk: Tk{Agg,Cairo} backends
pyside2: alternative for Qt5{Agg,Cairo} backends
pyside6: alternative for Qt6{Agg,Cairo} backends
python-pyqt5: Qt5{Agg,Cairo} backends [installed]
python-pyqt6: Qt6{Agg,Cairo} backends
python-gobject: for GTK{3,4}{Agg,Cairo} backend [installed]
python-wxpython: WX{Agg,Cairo} backend
python-cairo: {GTK{3,4},Qt{5,6},Tk,WX}Cairo backends [installed]
python-cairocffi: alternative for Cairo backends
python-tornado: WebAgg backend
ffmpeg: for saving movies [installed]
imagemagick: for saving animated gifs [installed]
ghostscript: usetex dependencies [installed]
texlive-bin: usetex dependencies [installed]
texlive-latexextra: usetex usage with pdflatex
python-certifi: https support
installing python-peewee...
Optional dependencies for python-peewee
python-psycopg2: for PostgreSQL database support
python-pymysql: for MySQL database support
installing python-py3nvml...
installing python-rx...
installing python-pyxdg...
installing python-xlib...
installing gwe...
installing libxnvctrl...
installing nvidia-settings...
installing opencl-nvidia...
Optional dependencies for opencl-nvidia
opencl-headers: headers necessary for OpenCL development
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia [pending]
installing lib32-opencl-nvidia...
Optional dependencies for lib32-opencl-nvidia
installing nvidia-dkms...
installing garuda-nvidia-config...
( 1/16) Creating system user accounts...
Creating group 'nvidia-persistenced' with GID 143.
Creating user 'nvidia-persistenced' (NVIDIA Persistence Daemon) with UID 143 and GID 143.
( 2/16) Reloading system manager configuration...
( 3/16) Reloading device manager configuration...
( 4/16) Arming ConditionNeedsUpdate...
( 5/16) Install DKMS modules
==> dkms install --no-depmod nvidia/515.43.04 -k 5.17.9-zen1-1-zen
With nomodeset even nouveau stops working
I believe the full parameter should be nomodeset=1.
However, I am not an nvidia user, so I'm not overly familiar with what is required to get their basterdized drivers working. :wink:
How long does it get stuck on the dkms install?
Depending on how quick your machine is, this could take up to 2 or even 3mins.
I waited 10 minutes. Also if I am in tty I get multiple hardware errors.
What are the errors? Output to a text file and paste them into the thread, perhaps the errors will be meaningful to someone in the forum.
I try, however for the most part there are dumps of the CPU registers and RAM sectors as I have seen.
Since they are direct logs to the tty a screenshot is the only way I was able to show those logs.
man pastebinit
Not even a downgrade seems to help…
