Nvidia 545.29.06 drivers won't work with Wayland
My Desktop (AMD 3700x, Nvidia 3070, Samsung G7 monitor connected via DisplayPort) stays black if I try to login to KDE Wayland session, login and using X11 works fine?
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5e516bea-8b4f-4eb1-a16d-e0ea74e81fbb rw rootflags=subvol=@
quiet resume=UUID=70f8141f-59be-49eb-b01a-c9a9be45be87 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5003
date: 10/07/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3734 high: 4314 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4313 2: 3902
3: 3862 4: 3600 5: 3600 6: 3593 7: 3591 8: 3600 9: 3491 10: 4314 11: 4028
12: 3600 13: 3584 14: 3600 15: 3474 16: 3600 bogomips: 114989
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 09:00.0 chip-ID: 10de:2484 class-ID: 0300
Screen-1: 0 s-res: 3840x2160 s-dpi: 152 s-size: 642x361mm (25.28x14.21")
s-diag: 737mm (29")
Monitor-1: DP-2 note: disabled model: Samsung LS28AG700N serial: <filter>
built: 2022 res: 3840x2160 dpi: 97536 gamma: 1.2 size: 1x1mm (0.04x0.04")
diag: 734mm (28.9") ratio: 16:9 modes: max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 545.29.06
device-ID: 10de:2484 surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 09:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA BlackShark V2 Pro
lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 1532:0528 class-ID: 0300
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-2: Microsoft XBOX ACC driver: mt76x2u type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:5 chip-ID: 045e:02fe
IF: wlp4s0u4 state: up mac: <filter>
Device-3: ASUSTek AC51 802.11a/b/g/n/ac Wireless Adapter [Mediatek
MT7610U] driver: mt76x0u type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-2:3 chip-ID: 0b05:17d1 class-ID: 0000 serial: <filter>
IF: wlp6s0f1u2 state: down mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4
chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 931.51 GiB used: 399.25 GiB (42.9%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 37.9 C scheme: GPT
ID-1: / raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
used: 399.25 GiB (44.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-4: /var/log raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 4 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.35 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.8 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 383 Uptime: 23m wakeups: 0 Memory: total: 32 GiB
available: 31.23 GiB used: 4.72 GiB (15.1%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2001 libs: 569 tools: octopi,pamac,paru,yay
Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2024-01-10
Last full system update: 2024-01-30
With Wayland try using the following kernel boot parameter:
nvidia-drm.modeset=1
e.g. with:
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
but please be aware that there are endless discussions on Nvidia issues recently.
Just give a look at this long thread (not necessarily covering your issue):
I added nvidia-drm.modeset=1 in the grub but no change, still black screen in Wayland.
Thank you for effort anway, I 'll use x11 until next Nvidia downgrade / upgrade.
I’m on an AMD CPU with a 3070 connected to monitors via DP. Works here.
There was an issue a while back about going from X11 → Wayland in terms of the kscreen getting f’ed when doing so. The solution was to delete the kscreen configuration in your home directory. (I believe this is supposed to be fixed in Plasma / Gear / FW 6.)
