Not able to run any command using pacman due to corrupted PGP Signatures
When i try to install/remove/update a package using pacman, I get the following error
error: failed to commit transaction (invalid or corrupted package (PGP signature))
I’ve tried all solutions given on forums and stack exchange, but nothing seems to work.
On running update remote keyring i get
archlinux-keyring: /usr/bin/archlinux-keyring-wkd-sync exists in filesystem
archlinux-keyring: /usr/lib/systemd/system/archlinux-keyring-wkd-sync.service exists in filesystem
archlinux-keyring: /usr/lib/systemd/system/archlinux-keyring-wkd-sync.timer exists in filesystem
archlinux-keyring: /usr/lib/systemd/system/timers.target.wants/archlinux-keyring-wkd-sync.timer exists in filesystem
archlinux-keyring: /usr/share/pacman/keyrings/archlinux-revoked exists in filesystem
archlinux-keyring: /usr/share/pacman/keyrings/archlinux-trusted exists in filesystem
archlinux-keyring: /usr/share/pacman/keyrings/archlinux.gpg exists in filesystem
Running the following commands also results in the error above.
sudo pacman -Sy archlinux-keyring chaotic-keyring
sudo pacman -Syu
On trying garuda-update it asks to import a bunch of keyrings and throws errors like
error: wget: signature from "T.J. Townsend <[email protected]>" is unknown trust
:: File /var/cache/pacman/pkg/wget-1.24.5-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
presumably for all the packages.
Any idea how I can fix this issue?
The output of sudo garuda-inxi:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=124ef93f-82c8-4529-9ac1-171f3dcd3471 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland with: krunner
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IU_FA506IU
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IU v: 1.0 serial: <filter>
uuid: d1f66fbe-b0d7-9d4d-bf77-1368223eae04 UEFI: American Megatrends
v: FA506IU.320 date: 06/01/2022
ID-1: BAT1 charge: 3.4 Wh (11.1%) condition: 30.6/48.1 Wh (63.6%)
volts: 11.7 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: charging
Info: model: AMD Ryzen 7 4800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
microcode: 0x8600104
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1587 high: 2900 min/max: 1400/2900 boost: enabled
base/boost: 2900/4300 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 2900 11: 1400 12: 2900
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 92626
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 51.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 13d3:56a2
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0xb78d built: 2019 res: 1920x1080
hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.8.7-zen1-1-zen) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 Ti driver: nvidia v: 550.76
device-ID: 10de:2191 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 04ca:4005
Report: btmgmt ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 128.83 GiB (11.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1002 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 49.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 262d 19h cycles: 9,880
read-units: 513,616,146 [262 TB] written-units: 65,940,982 [33.7 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 0001 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 132d 5h cycles: 9791
read: 9.1 TiB written: 4.06 TiB Old-Age: g-sense error rate: 302 Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
used: 128.83 GiB (54.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.18 GiB used: 2.98 GiB (41.5%)
System Temperatures: cpu: 59.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): cpu: 2500
Memory: total: 8 GiB note: est. available: 7.18 GiB used: 4.91 GiB (68.4%)
Processes: 409 Power: uptime: 9h 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.83 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1739 libs: 426 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date:     2023-11-28
Last full system update: 2024-04-23
Is partially upgraded:   Yes
Failed units:            [email protected]
Another update could help.
Use garuda-update (update or upd) in terminal. It solves most of the time all pacman probleme.
Try refreshing the signatures with:
sudo pacman-key --refresh-keys
Like I’ve mentioned, garuda-update doesn’t work and gives more errors
Tried it. Nothing changed, got the following error in the end
gpg: error retrieving '[email protected]' via WKD: End of file
gpg: error reading key: End of file
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key FC1B547C8D8172C8: "Levente Polyak (anthraxx) <[email protected]>" 5 new user IDs
gpg: key FC1B547C8D8172C8: "Levente Polyak (anthraxx) <[email protected]>" 10 new signatures
gpg: key FC1B547C8D8172C8: "Levente Polyak (anthraxx) <[email protected]>" 13 signatures cleaned
gpg: Total number processed: 1
gpg:           new user IDs: 5
gpg:         new signatures: 10
gpg:     signatures cleaned: 13
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   5  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:   5  signed:   0  trust: 1-, 0q, 0n, 4m, 0f, 0u
gpg: next trustdb check due at 2030-06-23
If that’s the end, then it’s not complete. Try again and wait, it will take a while.
I mean there were many gpg keys listed but they were unchanged. This is the full output
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
gpg: error retrieving '[email protected]' via WKD: No fingerprint
gpg: key 57F3D9CC660431DD: "Nico Jensch <[email protected]>" not changed
gpg:              unchanged: 1
gpg: error retrieving '[email protected]' via WKD: No data
gpg: error reading key: No data
gpg: key 95A6D49D0BBD2A8B: "Nico Jensch (Chaotic-AUR '22) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FA1A593985BF2B72: public key "[email protected] <[email protected]>" imported
gpg:               imported: 1
pub   rsa2048 2019-08-13 [SC]
CEDFFAE09EA27C2ECF84C699FA1A593985BF2B72
uid           [ unknown] [email protected] <[email protected]>
sub   rsa2048 2019-08-13 [E]
gpg: key 3056513887B78AEB: "Pedro Henrique Lara Campos <[email protected]>" notchanged
gpg:              unchanged: 1
gpg: key D6C9442437365605: "TNE <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 749E88C8EC38D662: "Naman (Keygen for Chaotic AUR) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FAF4946E8D60D074: "SGS Garuda Linux <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 8ADB4AEC585061CF: "Nico Jensch (Chaotic-AUR birdrepo builder) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key A6234074498E9CEE: "Christian Hesse <[email protected]>" 8 new signatures
gpg:         new signatures: 8
pub   rsa2048 2011-08-12 [SC]
02FD1C7A934E614545849F19A6234074498E9CEE
uid           [  full  ] Christian Hesse <[email protected]>
sub   rsa2048 2011-08-12 [E]
sub   cv25519 2019-08-29 [E]
sub   ed25519 2019-08-29 [S]
gpg: key 51E8B148A9999C34: "Evangelos Foutras <[email protected]>" 3 new user IDs
gpg: key 51E8B148A9999C34: "Evangelos Foutras <[email protected]>" 3 new signatures
gpg: key 51E8B148A9999C34: "Evangelos Foutras <[email protected]>" 9 signatures cleaned
gpg:           new user IDs: 3
gpg:         new signatures: 3
gpg:     signatures cleaned: 9
gpg: key 4AC5588F941C2A25: 2 duplicate signatures removed
gpg: key 4AC5588F941C2A25: "Antonio Rojas <[email protected]>" 3 new user IDs
gpg: key 4AC5588F941C2A25: "Antonio Rojas <[email protected]>" 3 new signatures
gpg: key 4AC5588F941C2A25: "Antonio Rojas <[email protected]>" 8 signatures cleaned
gpg:     signatures cleaned: 8
gpg: key 0F65C7D881506130: "Maxime Gauduin <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2022-01-30 [SC]
95220BE99CE6FF778AE0DC670F65C7D881506130
uid           [ unknown] Maxime Gauduin <[email protected]>
sub   rsa4096 2022-01-30 [E]
sub   rsa4096 2022-01-30 [A]
gpg: key 94657AB20F2A092B: "Andreas Radke <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-05-14 [SC]
ADC8A1FCC15E01D45310419E94657AB20F2A092B
uid           [ unknown] Andreas Radke <[email protected]>
sub   rsa2048 2011-05-14 [E]
gpg: key 9D4C5AA15426DA0A: "Frederik Schwan <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2018-10-31 [SCA] [expires: 2024-12-21]
05C7775A9E8B977407FE08E69D4C5AA15426DA0A
uid           [ unknown] Frederik Schwan <[email protected]>
sub   ed25519 2020-04-18 [A] [expires: 2024-12-21]
sub   cv25519 2018-10-31 [E] [expires: 2024-12-21]
gpg: key 139B09DA5BF0D338: "David Runge <[email protected]>" not changed
gpg: key 7258734B41C31549: "David Runge <[email protected]>" not changed
gpg: Total number processed: 2
gpg:              unchanged: 2
pub   ed25519 2022-05-10 [SC] [expires: 2026-05-09]
991F6E3F0765CF6295888586139B09DA5BF0D338
uid           [ unknown] David Runge <[email protected]>
sub   ed25519 2022-05-10 [A] [expires: 2026-05-09]
sub   ed25519 2023-08-12 [S]
sub   cv25519 2022-05-10 [E] [expires: 2026-05-09]
gpg:              unchanged: 2
gpg: key 59E43E106B247368: "Leonidas Spyropoulos <[email protected]>" notchanged
gpg: key 244740D17C7FD0EC: "Leonidas Spyropoulos (Arch Linux Packager key) <[email protected]>" not changed
gpg:              unchanged: 2
pub   rsa4096 2017-06-18 [SC] [expires: 2025-07-18]
B4B759625D4633430B74877059E43E106B247368
uid           [ unknown] Leonidas Spyropoulos <[email protected]>
sub   rsa4096 2022-01-11 [A]
sub   rsa4096 2017-06-18 [E]
gpg:              unchanged: 2
gpg: key 76A5EF9054449A5C: "Pierre Schmitz <[email protected]>" not changed
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <[email protected]>" not changed
gpg:              unchanged: 2
pub   ed25519 2022-10-31 [SC] [expires: 2037-10-27]
3E80CA1A8B89F69CBA57D98A76A5EF9054449A5C
uid           [ unknown] Pierre Schmitz <[email protected]>
sub   ed25519 2022-10-31 [A] [expires: 2037-10-27]
sub   cv25519 2022-10-31 [E] [expires: 2037-10-27]
gpg:              unchanged: 2
gpg: key C06086337C50773E: 1 duplicate signature removed
gpg: key C06086337C50773E: "Jelle van der Waa <[email protected]>" 1 new user ID
gpg: key C06086337C50773E: "Jelle van der Waa <[email protected]>" 2 new signatures
gpg: key C06086337C50773E: "Jelle van der Waa <[email protected]>" 8 signatures cleaned
gpg:           new user IDs: 1
gpg:         new signatures: 2
gpg: key B02854ED753E0F1F: "Anatol Pomozov (Arch Linux developer account) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-02-04 [SC] [expires: 2026-10-25]
8E1992167465DB5FB045557CB02854ED753E0F1F
uid           [ unknown] Anatol Pomozov (Arch Linux developer account) <[email protected]>
sub   rsa4096 2014-02-04 [E] [expires: 2026-10-25]
gpg: key 19802F8B0D70FC30: public key "Jan Alexander Steffens (heftig) <[email protected]>" imported
gpg: key B8AC08600F108CDF: "Jan Alexander Steffens (heftig) <[email protected]>" 6 new signatures
gpg:               imported: 1
gpg:         new signatures: 6
pub   ed25519 2020-05-11 [SC]
A2FF3A36AAA56654109064AB19802F8B0D70FC30
uid           [ unknown] Jan Alexander Steffens (heftig) <[email protected]>
sub   ed25519 2020-05-11 [A]
sub   ed25519 2020-05-11 [S]
sub   cv25519 2020-05-11 [E]
gpg: key 786C63F330D7CB92: "Felix Yan <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2012-01-20 [SC]
B5971F2C5C10A9A08C60030F786C63F330D7CB92
uid           [ unknown] Felix Yan <[email protected]>
sub   rsa4096 2012-01-20 [E]
gpg: key D4A753468A5A5B67: "Caleb Maclennan <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-07-12 [SC] [expires: 2024-08-11]
CCB34EBBB9541EF3F7B366C1D4A753468A5A5B67
uid           [ unknown] Caleb Maclennan <[email protected]>
sub   rsa4096 2021-07-12 [S] [expires: 2024-08-11]
sub   cv25519 2021-07-12 [E] [expires: 2024-08-11]
gpg: key 39E4B877E62EB915: "Sven-Hendrik Haase <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-09-10 [SC]
8FC15A064950A99DD1BD14DD39E4B877E62EB915
uid           [ unknown] Sven-Hendrik Haase <[email protected]>
sub   rsa4096 2022-07-10 [A]
sub   rsa4096 2011-09-10 [E]
gpg: key F296BDE50368C6CE: "T.J. Townsend <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-08-08 [SC]
54C1FD273361EA514A237793F296BDE50368C6CE
uid           [ unknown] T.J. Townsend <[email protected]>
sub   ed25519 2022-09-04 [SA]
sub   cv25519 2022-08-08 [E]
gpg: key FDC3040B92ACA748: "Robin Candau <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2023-01-25 [SC] [expires: 2026-01-24]
262A58EC6C51F7EA395B2E2DFDC3040B92ACA748
uid           [ unknown] Robin Candau <[email protected]>
sub   rsa4096 2023-01-25 [E] [expires: 2026-01-24]
gpg: key A91764759326B440: 1 duplicate signature removed
gpg: key A91764759326B440: "Lukas Fleischer <[email protected]>" 5 new user IDs
gpg: key A91764759326B440: "Lukas Fleischer <[email protected]>" 6 new signatures
gpg: key A91764759326B440: "Lukas Fleischer <[email protected]>" 1 new subkey
gpg: key A91764759326B440: "Lukas Fleischer <[email protected]>" 8 signatures cleaned
gpg:            new subkeys: 1
gpg: key F6B1610B3ECDBC9F: "Andrew Crerar <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2017-11-17 [SC] [expires: 2025-11-16]
601F20F1D1BBBF4A78CF5B6DF6B1610B3ECDBC9F
uid           [ unknown] Andrew Crerar <[email protected]>
sub   rsa2048 2017-11-17 [E] [expires: 2025-11-16]
gpg: key 001CF4810BE8D911: "Jakub Klinkovský <[email protected]>" 5 signatures cleaned
gpg:     signatures cleaned: 5
gpg: key 019A7474297D8577: "Daniel Bermond <[email protected]>" not changed
gpg: key E85B8683EB48BC95: "Daniel Bermond <[email protected]>" not changed
gpg:              unchanged: 2
pub   rsa2048 2016-06-27 [SC]
3FFA6AB7B69AAE6CCA263DDE019A7474297D8577
uid           [ unknown] Daniel Bermond <[email protected]>
sub   rsa2048 2016-06-27 [E]
gpg: key E85B8683EB48BC95: "Daniel Bermond <[email protected]>" 5 signatures cleaned
gpg: key 93B11DAA4C197E3D: "Christian Heusel (gromit packager key) <[email protected]>" 5 signatures cleaned
gpg: key 632C3CC0D1C9CAF6: "Balló György <[email protected]>" 4 signatures cleaned
gpg:     signatures cleaned: 4
gpg: key 07D06351CA5B31BE: "Torsten Keßler <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-12-07 [SC] [expires: 2025-12-31]
04CF0CD6F6EE93AE1896F58407D06351CA5B31BE
uid           [ unknown] Torsten Keßler <[email protected]>
sub   cv25519 2022-12-07 [E] [expires: 2025-12-31]
gpg: key 3FDDD575826C5C30: "Chih-Hsuan Yen <[email protected]>" not changed
gpg: key 56EC201BFC794362: "Chih-Hsuan Yen <[email protected]>" not changed
gpg:              unchanged: 2
pub   dsa3072 2016-04-05 [SC] [revoked: 2022-12-10]
481C4474AF1572165AE4C6AF3FDDD575826C5C30
uid           [ revoked] Chih-Hsuan Yen <[email protected]>
gpg:              unchanged: 2
gpg: key EA4F7B321A906AD9: "Daniel M. Capella <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-01-03 [SC] [expires: 2024-11-09]
04DC3FB1445FECA813C27EFAEA4F7B321A906AD9
uid           [ unknown] Daniel M. Capella <[email protected]>
sub   rsa4096 2016-01-03 [E] [expires: 2024-11-09]
gpg: key C32217F6F13FF192: "Alexander F. Rødseth <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2022-05-30 [SC] [expires: 2064-05-19]
8A9BC5819C54FEB3DC2A9B48C32217F6F13FF192
uid           [ unknown] Alexander F. Rødseth <[email protected]>
sub   rsa4096 2022-05-30 [A] [expires: 2064-05-19]
sub   rsa4096 2022-05-30 [E] [expires: 2064-05-19]
gpg: key 9C02FF419FECBE16: "Morten Linderud <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-09-05 [SC]
C100346676634E80C940FB9E9C02FF419FECBE16
uid           [ unknown] Morten Linderud <[email protected]>
sub   rsa4096 2018-11-26 [A]
sub   rsa4096 2014-09-05 [E]
sub   rsa4096 2018-11-13 [S]
have you tried a,
garuda-update remote fix
Didn’t work. Got this error
If exist use --overwrite to be sure you got the new key(s).
That did not work, unfortunately. It gives the same error of conflicting files
Quick and dirty: load and restore a snapshot from before the issue and try again with
garuda-update
Thanks! I did that and it worked. Altough I’m not sure what changes happened due to restoring an older snapshot. The files I had seem pretty upto-date. What really changes when we restore a snapshot?
