terminal output on installing tlp through pacman:
: tlp and performance-tweaks are in conflict. Remove performance-tweaks? [y/N] y
:: removing performance-tweaks breaks dependency 'performance-tweaks' required by garuda-common-settings
well you cannot do it unless you want to remove every garuda specific package
do i also need to remove garuda common setting along with performance package
yes everything related to garuda
either use tlp or use garuda
its that simple
And
So what does the "performance-tweaks" do then? Is TLP still needed
Performance-tweaks is like the Garuda way of performance mode as in windows which will increase the efficiency of machine compromising the battery life while tlp increase battery life compromising performance that's why they both are in conflict
