Not able to access the system after an upgrade
Hello Garuda users.
I am facing a weird issue. I have been using Garuda Kde Dragonized edition in my external usb for some time. Now I decided to wipe my windows notebook and move my external usb to it. I was able to do so, but after an upgrade, everything stop working. I am able to access again the system using a new implementation I did in an external drive and running garuda-boot-repair. But I can only access the system choosing advanced options and selecting the linux-zen. I also have Linux-hardener, but it never work again after the update. I am pasting below the inxi before the update and after the update when I have to use the advanced option and select linux-zen and do an update-grub.
garudaa-inxi before update from an old snapshot
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b5e980c3-edb0-48df-90bc-594fb4248e54 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 20NKS5YH03 v: ThinkPad T495
Mobo: LENOVO model: 20NKS5YH03 v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R12ET61W(1.31 ) date: 07/28/2022
ID-1: BAT0 charge: 49.1 Wh (97.2%) condition: 50.5/50.5 Wh (100.0%)
volts: 12.8 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: not charging cycles: 77
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1487 high: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 2100
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33536
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 06:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 4-2.1:4 chip-ID: 5986:2113 class-ID: 0e02
Screen-1: 0 s-res: 2944x1080 s-dpi: 96 s-size: 776x285mm (30.55x11.22")
s-diag: 827mm (32.55")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Philips PHL 272V8
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: LG Display 0x05fa
built: 2018 res: 1024x768 hz: 60 dpi: 84 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
5.19.10-zen1-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 bus-ID: 4-1:2 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.35 TiB used: 264.42 GiB (19.1%)
model: MZVLB512HBJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 126d 22h cycles: 3,643 read-units: 79,210,640
[40.5 TB] written-units: 55,156,050 [28.2 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: KingSpec model: P4-960
size: 894.25 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0056 drive rev: SN3060
temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 57d 11h cycles: 486
read: 2.53 TiB written: 3.9 TiB
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Cruzer Blade size: 14.91 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 264.4 GiB
(55.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 17.3 MiB
(5.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 264.4
GiB (55.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 264.4
maj-min: 259:2
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 264.4
maj-min: 259:2
ID-1: swap-1 type: zram size: 13.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 311 Uptime: 1m wakeups: 1 Memory: 13.53 GiB used: 4.13 GiB
(30.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1824 pm: pacman pkgs: 1817
libs: 405 tools: octopi,pamac,paru pm: flatpak pkgs: 7
inxi: 3.3.21
Garuda (2.6.7-1):
System install date:     2022-06-26
Last full system update: 2022-09-22
Failed units:            plymouth-deactivate.service
garuda-inxi after the update where i can only access the system doing some work arounds as decribed above.
root=UUID=b5e980c3-edb0-48df-90bc-594fb4248e54 rw single
rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
serial: <superuser required> UEFI: LENOVO v: R12ET61W(1.31 )
date: 07/28/2022
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx bits: 64
Speed (MHz): avg: 1445 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1225 2: 1400
3: 1400 4: 1400 5: 2100 6: 1298 7: 1400 8: 1341 bogomips: 33537
chip-ID: 1002:15d8 class-ID: 0300 temp: 67.0 C
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.48
6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
class-ID: 0480
Local Storage: total: 1.35 TiB used: 275.25 GiB (19.9%)
rev: 5M2QEXF7 temp: 48.9 C scheme: GPT
size: 894.25 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0056 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 275.24 GiB
(57.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
(5.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 275.24
GiB (57.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 275.24
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.56 GiB (99.98%) used: 275.24
ID-1: swap-1 type: zram size: 13.53 GiB used: 409.8 MiB (3.0%)
System Temperatures: cpu: 67.0 C mobo: N/A gpu: amdgpu temp: 67.0 C
Fan Speeds (RPM): fan-1: 2700 fan-2: 2700
Processes: 331 Uptime: 30m wakeups: 1 Memory: 13.53 GiB used: 5.83 GiB
(43.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1829 pm: pacman pkgs: 1822
libs: 406 tools: octopi,pamac,paru pm: flatpak pkgs: 7 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
Last full system update: 2022-10-22
Failed units:            plymouth-deactivate.service systemd-networkd-wait-online.service
I appreciate any help.
Regards,
JP
What was your method for moving the installation over from one disk to the other?
In general, I would say the safest way to do something like this would be to re-install Garuda from scratch, then transfer over your files afterward with rsync or similar.
Can you be more specific about what is happening?
Thanks for your update Blush.
The firs time i tried using clonezilla, It took an year to clone, and after all, it did not work, meaning not able to access the system.
So I decided to install Garuda from scratch in my noteboot (where I had windows), and generate an image of my btrfs file system using clonezilla.
I restore the partition to the second partition and I did nothing in the first partition, where the boot/efi is (FAT32 partition).
Then I did an grub update and it worked, meaning it appears the custom menu I had, but if froze the first time. Then I retrieve an snapshot from two months ago an everything was working fine without any issue. I could reboot as many times as I want.
The problem began when I did an update (garuda-update remote keyring. After updating the system, it stop giving access to it.
So, I did not install everything again, what I was trying to avoid at all cost, and I was able to access (always) the system, until I update it.
Regards,
JP
I forget to mention that in the first time I follow the guidance of the document How to Chroot Garuda Linux FAQ
There are a few different things that could be going on, but this move might be causing some issues:
Grub stores its stuff on the EFI partition, but the kernel is stored in /boot which is on the other partition. I don’t know if that is causing your problem or not but it seems like there is space for something to go wrong here.
Try something like this:
  • Delete EFI boot entries and re-install (not update) grub, as is described in this post:
  • Reinstall all kernels you would like to keep using (don’t forget to reinstall the headers too)
  • Then update Grub, reboot and check again.
Hi Bluish,
I follow the guidance you gave me and it was not working. I decided to remove the kernel linux-hardened. I though it was the root cause of the issue.
It did not solve. Now I am able to access the system using the kernel zen in recovery mode. I suspect it is a hardware or anything weird incompatible. If I do not update the system, it works and I can reboot as many times as I wish, but if I update, them my problems begin.
In rescue mode I typed journalctl -xb, but I do not have knowledge to understand if the report is pointing to an issue or not.
Anyway, thanks for your help and time. If you have any other suggestion besides reinstalling the system again, I appreciate.
I do not want to install it again, since I am not sure what is causing this issue and I am afraid, I could install all again and have the same issue again.
Regards,
Gustavo Coutinho
In recue mode I can use all the installed packages.
I do still think a fresh install will be your best bet, although I certainly can appreciate your reluctance to start over.
Just a quick sanity check: all the UUIDs match up in /etc/fstab, right? Run lsblk -f and double-check for a mistake.
One more thing you could try would be to install the LTS kernel and see if that works normally.
If not, I would say it is probably not a kernel issue--more likely something with the data transfer has gone badly, and the path to a fix will not be simple or obvious.
