i recently installed Stremio and it uses use nodejs-lts-galium as a dependency however i also want to install visual studio code and it requries nodejs-lts-fermium as a dependancy which conflicts with the galium one hence it throws a error. i dont wanna uninstall anyine and wanna install both on my machine
when installing vs studio code on my machine which already has stremio, this the output.....
:: nodejs-lts-fermium and nodejs-lts-gallium are in conflict (nodejs). Remove nodejs-lts-gallium? [y/N] y
:: removing nodejs-lts-gallium breaks dependency 'nodejs-lts-gallium' required by stremio
==> ERROR: 'pacman' failed to install missing dependencies.
I'm curious, what did you make signing up to the Garuda forum in the first place?
This is is a dependency conflict, its either one or another in this case.
yea dumb move on my part i was just scanning the web for my issue and found a similar one here but not really my problem so without noticing what site m on i made an account and posted my question.
anyways getting to the problem that basically means that i do have to select between the 2 softwares and there i no way i cant install them both together right? that sucks
