No sound after reinstalling Pulseaudio
Greetings Garuda users;
After reinstalling Pulseaudio after unsolvable issues with Pipewire (mainly cackling and distortion when the volume peaked in every application), the sound system ALSA failed to open a slave PCM signal, returning the following error upon using aplay for testing:
aplay "/path/to/music/file.mp3"
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
aplay: main:834: audio open error: No such file or directory
My laptop has an IDT soundcard, which has been proven fussy to setup even on Windows systems, maybe it's something related?
The garuda-inxi out:
  Kernel: 6.1.50-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=fe4bf09f-7ee8-4b8c-b7d5-e0364790b11c rw rootflags=subvol=@
  Type: Laptop System: Hewlett-Packard product: HP ProBook 655 G1
    v: A3008DD11303 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 1992 v: KBC Version 05.34
    serial: <superuser required> UEFI: Hewlett-Packard v: L72 Ver. 01.47
    date: 07/30/2018
  Info: model: AMD A8-5550M APU with Radeon HD Graphics bits: 64 type: MT MCP
    arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
    model-id: 0x13 (19) stepping: 1 microcode: 0x600111F
  Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
    desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
  Speed (MHz): avg: 1908 high: 2053 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 1872 2: 2030
    3: 2053 4: 1678 bogomips: 16776
  Device-1: AMD Richland [Radeon HD 8550G] vendor: Hewlett-Packard
    driver: radeon v: kernel alternate: amdgpu arch: TeraScale-3
    code: Northern Islands process: TSMC 32nm built: 2010-13 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:01.0
    chip-ID: 1002:990d class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Webcam
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-5:3 chip-ID: 05c8:0369 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
    gpu: radeon display-ID: :0.0 screens: 1
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4851 built: 2012
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
  API: OpenGL v: 4.5 Mesa 23.1.6-arch1.4 renderer: AMD ARUBA (DRM 2.50.0 /
    6.1.50-1-lts LLVM 16.0.6) direct-render: Yes
  Device-1: AMD Trinity HDMI Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
    v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  API: ALSA v: k6.1.50-1-lts status: kernel-api with: aoss
  Server-1: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl,pamixer,pavucontrol
    lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Broadcom BCM43228 802.11a/b/g/n driver: wl v: kernel
    modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14e4:4359 class-ID: 0280
  Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
    driver: hid-generic,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 8-2.2:3 chip-ID: 0458:6001 class-ID: 0301
  Device-1: Broadcom HP Portable Bumble Bee driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0a5c:21f1
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 10010c
  Local Storage: total: 465.76 GiB used: 126.01 GiB (27.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    tech: SSD serial: <filter> fw-rev: 032 scheme: GPT
    used: 126.01 GiB (27.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-1: swap-1 type: zram size: 6.97 GiB used: 512 KiB (0.0%) priority: 100
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: radeon temp: 40.0 C
  Processes: 236 Uptime: 18m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 6.97 GiB used: 2.35 GiB (33.7%) Init: systemd v: 254
  pm: pacman pkgs: 1961 libs: 524 tools: octopi,pamac,paru,yay pm: rpm pkgs: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.29
  System install date:     2023-05-01
  Last full system update: 2023-09-01 ↻
  Relevant software:       NetworkManager dracut
It also makes web browsers such as Firefox crash upon loading a video or playing files, any guidance of how to fix this issue?
Thank you in advance!
