No output sound at all but mic is working
Hi there, i need some help here.
trying to get this working since some days now.
it appeared across all distributions i tried. regata fedora …
while everything seems ok, no output.
i tried some things found in various forum across linux, but nothing helps.
alsamixer is working fine, i unmuted everything.
i hope u can give some hints how to handle this problem.
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5fafb690-2f20-40f2-bbb3-26a074aab3e7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: Z170 Gaming K4
serial: <superuser required> UEFI: American Megatrends v: P7.30
date: 01/23/2018
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 983 high: 1200 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1065 3: 800
4: 800 5: 800 6: 1200 7: 800 8: 1200 bogomips: 63999
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: CardExpert driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia wayland:
drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 545.29.06
device-ID: 10de:1b81 surfaces: xcb,xlib,wayland
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock
Device-2: NVIDIA GP104 High Definition Audio vendor: CardExpert
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Trust USB microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4
chip-ID: 145f:02b4 class-ID: 0300 serial: <filter>
Device-4: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api with: aoss
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: ASRock
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 1969:e0a1 class-ID: 0200
Local Storage: total: 2.48 TiB used: 12.67 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-AG41TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM13.0 temp: 28.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 35.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD size: 447.13 GiB
serial: <filter> fw-rev: 2A0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
used: 12.67 GiB (2.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.56 GiB used: 2.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 26.0 C pch: 45.5 C mobo: N/A
Fan Speeds (rpm): cpu: 946
Processes: 267 Uptime: 0m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 2.77 GiB (17.8%) Init: systemd v: 255
pm: pacman pkgs: 1771 libs: 520 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2024-01-07
Last full system update: 2024-01-07
╰─λ cat /proc/asound/cards
File: /proc/asound/cards
0 [PCH            ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xdf420000 irq 149
1 [NVidia         ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xdf080000 irq 17
2 [microphone     ]: USB-Audio - Trust USB microphone
Trust USB microphone Trust USB microphone at usb-0000:00:14.0-7, full speed
3 [Webcam         ]: USB-Audio - C922 Pro Stream Webcam
C922 Pro Stream Webcam at usb-0000:00:14.0-8, high speed
[    4.410726] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    4.466986] snd_hda_codec_realtek hdaudioC0D0: ALC1150: SKU not ready 0x00000000
[    4.467446] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1150: line_outs=3 (0x14/0x15/0x16/0x0/0x0)type:line
[    4.467450] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.467452] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    4.467453] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    4.467455] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[    4.467455] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    4.467456] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    4.467458] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    4.467458] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    5.664919] usbcore: registered new interface driver snd-usb-audio
╰─λ inxi -A
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
type: USB
type: USB
Server-1: PipeWire v: 1.0.0 status: active
Just an hypothesis but, I see that you have two sound cards could this be the cause of issue? perhaps a race condition is occurring and hence neither card is getting the sound to output. Try to set a default sound card with the below archwiki article. Test both cards alternatively.
https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture#Configuring_the_index_order_via_kernel_module_options
Would also suggest looking at this post and the one’s below it,
the 2nd is the nvidia hdmi device.
but i solved it finally.
i unmuted all but didnt noticed the small MM in the alsamixer. which can be turned on by hitting “m”.
it wasnt seen in any of the options in soundpanel.
thx to your link i was able to find the most simple solution thx :slight_smile:
