Kernel: 6.1.15-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fb54b2b3-d688-40f0-9173-7c4efc19a007 rw rootflags=subvol=@
quiet
cryptdevice=UUID=ca4e6008-4cd8-42f6-95df-fe3c97618770:luks-ca4e6008-4cd8-42f6-95df-fe3c97618770
root=/dev/mapper/luks-ca4e6008-4cd8-42f6-95df-fe3c97618770 quiet splash
resume=/dev/mapper/luks-9ea7b2b1-7919-4f17-8205-e87d8e99e757 loglevel=3
Type: Laptop System: Dell product: Latitude E7470 v: N/A
Mobo: Dell model: 0T6HHJ v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.36.3 date: 09/18/2022
ID-1: BAT0 charge: 41.1 Wh (100.0%) condition: 41.1/55.0 Wh (74.8%)
volts: 8.4 min: 7.6 model: Samsung SDI DELL 1W2Y26A type: Li-poly
serial: <filter> status: full
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2800 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 2800 2: 2800 3: 2800 4: 2800 bogomips: 22408
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1536x864 s-dpi: 96 s-size: 406x229mm (15.98x9.02")
s-diag: 466mm (18.35")
Monitor-1: eDP-1 model: AU Optronics 0x1036 built: 2014 res: 1536x864
hz: 60 dpi: 126 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 2560x1440
missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.1.15-1-lts running: yes
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-2: Intel driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A
bus-ID: 02:00.0 chip-ID: 8086:093c class-ID: 0280
Local Storage: total: 2.08 TiB used: 1.48 TiB (71.3%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SL32G size: 29.03 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: THNSN5256GPU7
NVMe 256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 57DA4103
temp: 46.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD20NMVW-59EDZS7 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5200 serial: <filter> rev: 1005 scheme: GPT
ID-1: / raw-size: 229.66 GiB size: 229.66 GiB (100.00%)
used: 16.72 GiB (7.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ca4e6008-4cd8-42f6-95df-fe3c97618770
ID-2: /home raw-size: 229.66 GiB size: 229.66 GiB (100.00%)
ID-3: /var/log raw-size: 229.66 GiB size: 229.66 GiB (100.00%)
ID-4: /var/tmp raw-size: 229.66 GiB size: 229.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.57 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-9ea7b2b1-7919-4f17-8205-e87d8e99e757
System Temperatures: cpu: 45.0 C pch: 33.0 C mobo: 35.0 C
Fan Speeds (RPM): cpu: 0
Processes: 230 Uptime: 40m wakeups: 5 Memory: 7.57 GiB
used: 1.45 GiB (19.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1361
libs: 363 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-09
Last full system update: 2023-03-09 ↻
I am not getting onboard network connectivity to my eth port.
ifconfig and iplink only show the wireless card. How do I go about finding the driver for the ethernet port? Thanks for any tips!
